Tubing size for frame bracing
pontiac6269
Member
Jul 29, 2014
6
What size and kind of tubing do you use for bracing the frame? I have a 78 Cutlass Supreme that I'm building for drag racing. I want to brace the frame at the upper and lower control arm mounts, connect the rear shock area and some other areas that may need it. I had a 6 point roll bar installed last fall.
Thanks,
Eric
