I am re-installing the battery to the trunk and wondered what size wire do you all use to run from the alt back to your battery in the trunk? I don't want to go to small and loose volts due to the length and resistence.
Also, I know that the battery box needs to be mounted to the frame for it to be NHRA legal at the track. Anyone that has theres mounted and is track legal mind posting a pic of their set up and how they mounted it. Also, how they mounted and wired in the battery cut off switch. I have the Moroso style cut off switch that turns left/right vise the push pull style.
