I have a problem and I think I solved it .....Just wanna be sure is all.... I have a '84 Monte with the 12 bolt rear from a '69 Chevelle.....Running Weld 15x10" wheels with a 6" back space ( I think).. I keep eating the outside of the tires and rubbing the inner wheel wells when I have a few people on board..... After doing some math and checking the FAQ I think I need 15x8 tires with no more then 4 1/2" back space..........Oh yeah, I have the 275x60x15 tires. Is this a correct theory I have????
"This isn't necessarily something set in stone, because you can tweak things to run a pretty big tire. Some people are interested in drag racing, some want the biggest wheel diameter with ultra low profile tires. Since this is primarily a drag racing site, I'll say that a 275/60/15 is the largest rear street tire you can run and a 28x10.50 is the largest slick. I found that the McCreary L60-15 fit nicely. These should be used with 15x8" wheel and 3.5" backspacing. "
So with that in mind.....I believe I need the 15x8 wheel with the 4.5 back space to compensate for the width difference in the 12 bolt compared to the 10 bolt?? Thaks in advance!!!
