Wheel/Tire fitament on 82 Cutlass
bbcutlass
43
Auburn, Washington
I was wondering what you cutlass guys are running for rear setups. I currently have a stock width 9" with 15x8 draglites and 29x10.5 hoosier and I'm rubbing on the frame. I tried flipping the wheel around to see if the 3" Bs would help but then it looks as though my quarter panel is going to hit when I launch.
What I'm thinking right now is a 15x7 but then I will have to go with a shorter tire and then I'm going to be gear bound with the 4.86s that i have in the rear so I would have to buy smaller gears. any help would be appreciated. I would really love to run an 8" wheel with at least a 28 tall if not taller. Width on the tire isn't my biggest concern.
WDODGER
271
Cape Coral FL
tire help
hello i have a 1984 cutlass.I run a 15x8 weld prostars 3.5 back spacing,plus a 1/4 inch spacer.i runa mickey thompson 28x10.50 drag slick. i have a 9 inch. with 5/8 stud kit from moroso.they dont rub at all. the rear fender lip is not rolled or cut. hope this info will help.
mreese
171
KILGORE TX
Re: tire help
leave the spacer out and cut the lip off.
