Re: Which spaerkplugs for Dar heads???'s
Ditto Wagon - If you want a certain brand use a cross reference chart.
art Platinum 200 SBC 23° Aluminum Cylinder Head
Part# 11310000P thru 11420000P
Material: 355-T61 Aluminum
Comb Chambers: 64cc & 72cc
Intake Valve Dia: 2.02”
Intake Port volume: 200cc
Intake Port Dim: 1.195”w x 2.095”h
Int Port Location: Stock
Intake Gasket: Fel-Pro# 1205 Mr. Gasket 106
Exh Valve Dia.: 1.600”
Exh Port volume: 75cc
Exhaust Port Dim: 1.410”w x 1.350”t
Exh Port Location: Stock location & bolt pattern
Exhaust Gasket: Fel-Pro# 1404 Mr. Gasket 150c or Ultra Seal 5900
Flow, Intake: 264cfm @ .500” lift / 28”
Flow, Exhaust: 180cfm @ .600” lift / 28”
Head Bolts: Stock bolts can be used. We recommend ARP# 134-3601
Head Studs: ARP# 134-4001 or 234-4301 (12pt)
Manifold: Dart dual plane 42811000 or Dart single plane 42411000 with 4150 carb
Milling: Min. 58cc = .060” (.0065” = 1cc) Flat Mill
Angle mill .125” safely / .200” = 49cc 1.5° (carefully)
Pistons: Most 23°aftermarket pistons.
Push Rod length: Stock thru +.100” Should always measure (Stock length = 7.800”)
Push rod Guide Plate: Dart guide plate 27001110
Retainers: Steel (10°) / 1.250” ( 7°)
Spark Plug: Angle or straight, .750” reach, gasketed, Autolite AR3933
Spring Pockets: 1.550” OD (.030” deeper max)
Springs: Our Assembly: 1.250S = 110# @ 1.700” / .520” max Comp 981
1.437D = 130# @ 1.800” / .620” max Comp 987
1.550D = 195# @ 1.900” / .690” max Comp 954
Valve Length: Std 4.935” w/ 1.250 & 1.437 / 5.035” (+.100) w/ 1.550
Valve Stem Dia: .3415” - 11/32”
Valve Train: Std SBC 3/8” or 7/16” stud mount
Valve Guides: 1/2” OD Int = Mag-bronze Exh = Mag-bronze (.002” press)
Valve Guide length: 2.100”
Valve Guide clearance: .0014” - .002” (with our .3415 dia. valve stem)
Valve Guide Spacing: 1.890” exhaust moved .030” from intake
Valve Seats: Powder metal, .006” press
Valve Seat dim. Int - 2.160”x 1.810” x .350” Exh - 1.650”x 1.350”x .350”
Valve Seat angles: Int = 32° - 45° - 60° - 70°-80° Exh = 37° - 45° - radius
Stud Girdle: Retains standard SBC stud location. Recommended Dart PN # 64110002
Torque: Head Bolts = 70 ft/lb
Rocker Studs = 45 ft/lb
Manifold = 35 ft/lb
Block Use: Any SBC Iron or Aluminum
