I think it is a common problem... Which converter should i use or better said which stall speed or what factors are involved on the stall speed ?
Car is a 1979 Oldsmobile with a 350 chevy out of a corvette with a weiand open plenum intake and Holley 750cfm (3310) vakuum secondaries , camel hump heads and maybe other cam , but do not know exactly, hooker headers , 2,25 inch dual exhausts , about 280 hp at the wheels , weight should be as stock , but no a/c and Weld Draglites , so maybe a little lighter.
Trans is a th350 with shiftkit and a 2000stall converter(on break , on acceleration 2100 to 2200 , depending of trans temperature, rear is standard Olds , i think it has 2,29 gears , but will change to 3.3? or 3.73 soon.
Car goes really good over 3000 rpms up to 6000rpms , i think because of the carb - intake - rear combination...
So , i could get 2 differnt converters :
2500 to 3000
3000 to 3500
This is what they say ist the rpm stall range. As i know , on a smallblock in a light car they may end up at 2500to2600 and the second 3000to3100...maybe !?
I think a 3000 stall would be good for the car... or ???
What do you think ? What have you in your cars ?
Thank you for any ideas , help , informations !!!!!!!
I have some videos on youtube under : The79OldsCutlass
Greets , Carsten
2500 to 3000
3000 to 3500
Greets , Carsten
