white wire on column plug ???
79izfine
2,199
massachusetts
i have another post in this section the white wire on the steering colum plug was cut off the plug and butt connected together i was having an issue with all parking lights staying on with key off and turn signals wouldnt work so i decided to unplug the white wire and the parking lights turned off and my one blinker blinks the other blinker on cluster stays lit bad bulb but i didnt have brake lights so i decided to plug the white wire back together and i screwed in my brake switch further towards the pedal now everything works like it should i dont understand if the brake switch wasnt adjusted rite why the front parking lights would stay on with the rears am i on the right track if you could shed some light on the suject that would be great just incase it gives me further problems thanks
MalibuMan1979
506
flint, (lapeer), michigan
i am not sure because it was a long time ago, but the white wire is your brake light wire. i added malibu racings own wiring diagrams website... the white wire does come from the brake switch......
http://www.maliburacing.com/wiring_diagrams/RearTurn-Hazard-StopLight.jpg
