Body mounts
Dillon
New Member
Mar 3, 2013
Hello
Working on a 81 two door Malibu.
Got the body off the chassis to fix rear frame rail rot.
Problem I have is that when I loosened up body mount bolts three of them wouldn't come out. They just kept spinning and spinning. What I ended doing just so could get the body off was drill out the head on those three bolts.
I don't know what the technical word is for the part,,,,basically a cup link in the auto body with threads for bolting body to frame.
Question is how does one replace these cup links in the auto body?
I'm asking because I can't figure out if they are supposed to come out or would I have to cut small hole in body to access and replace the cup links.
Thank you for any help.
StreetBu
4,158
3
Upstate NY
You have to cut holes in the body fom the inside, some use a hole saw then just put a rubber plug in to fill the hole, others make 3 cuts and peel the body bodyback to get to them, then weld it back shut when done.
