Painting interior help
Moderator: Moderators
Post Reply
malibukeith
Post by malibukeith » Fri Mar 29, 2013 11:12 am
Hey all I need a paint pro. I've started painting my interior and am having a little bit of trouble in spots on it. Maybe I'm not doing the correct steps or something idk. I'm not experienced in painting at all. I'm getting fish eyes in a couple places and on one spot during clearing a piece it looks like the clear just got poured onto one spot and is kinda whitish? Anyway I hope someone can help me or tell me the steps they used because so far the 2 pieces I'm working on hasn't turned out perfect like I like :D. I did sand the pieces first by hand using 80 grit and then 100 grit. I think I'll buy a hand sander though as that took to long for my liking and didn't yield the results I think a sander could in 5 minutes. Thanks all MalibuKeith.
StreetBu
Re: Painting interior help
Post by StreetBu » Fri Mar 29, 2013 5:03 pm
Fish eyes are usually caused by grease. Did you wash them after you sanded them? I normally use some tide or dawn in a 5 gallon bucket and a green scotchbrite pad. Blow them dry with the air hose and you should be good to go.
'78 bu, 350/380hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, 18x9.5" wheels on all four corners with 275/35/18's, grey bucket seat Monte interior
malibukeith
Post by malibukeith » Fri Mar 29, 2013 9:49 pm
No I just rinsed them off. I guess I'll sand wash then re-paint the piece again. Thanks :D
lasttime78
Post by lasttime78 » Fri Mar 29, 2013 10:26 pm
You don't need to wash them with water and all that stuff its unnessary. Wipe them down with a 50/50 water and simply green. Then wipe them all down with rubbing alchohal let dry and don't touch with your hands after the alchohal wipe. Always use a micro fiber to hang or set them up to dry or where your going to paint them.
The simple green and water mix will take All and any armour all of!!
Remember when building your Malibu ( Cheap ain't Good and Good ain't Cheap! )
malibukeith
Post by malibukeith » Sat Mar 30, 2013 2:06 pm
Thanks a bunch. I'll try them both.
shvrolay
Contact:
Post by shvrolay » Sun Mar 31, 2013 6:43 am
Prep-Sol or a similar product. Should really be used before sanding as well as after.
-Bill
"Sometimes I think life is just a rodeo,
the trick is to ride and make it to the bell."
-John Fogerty
1979 Malibu Spt. Cpe., (Formerly a 41K Granny car) - ZZ502, TH400, 3.70/FxxD 9".
2003 S10 Sport-side, Ext. Cab, 4.3 L auto 2WD
2015 Cadillac SRX
1978 El Camino SS (factory 350/4 speed) son's car
Weirton Speed and Marine
malibukeith
Post by malibukeith » Sun Apr 07, 2013 4:26 pm
I take it that's a plastic prep or something? I really know little about painting.
StreetBu
Post by StreetBu » Sun Apr 07, 2013 4:49 pm
yep, well actually more of a pre-painting cleaner
Mike
Post by Mike » Sun Apr 07, 2013 8:55 pm
What are you using ? Spray can or compressor ? What product did you spray the stuff with ? I just did a set of lower door panels yesterday.
Post Reply
