1/4 window removal???
rodneypierce
473
Cedar Rapids, IA
Use a knife to slide in between the trim and the window and cut as much of the urethane away as you can. Then I used a 4 inch wide putty knife and a mallet and slowly tapped it down past the urethane between the glass and trim, all the way around. And it popped right out.
81classic
2,833
North Port, Fl
you have to take out the interior trim and remove the brackets that hold them in. Mine fell out once the brackets were removed but you might have to cut out the sealant
1981Regal
1,274
Cincinnati, Ohio
rodneypierce
473
Cedar Rapids, IA
1981Regal said:
This is an awesome write up! If it wouldnt have been for that, I would have never thought to convert mine to a standard pillar car.
