1978-80 cutlass cruiser header panel on 1982 cutlass cruiser
Autobody and Paint Tech Discussion
Moderator: Moderators
Post Reply
Andy G
Newbie
Post by Andy G » Thu Jan 22, 2015 2:32 am
Will a 1978 - 80 cutlass cruiser wagon header panel be a direct bolt on to a 1982 cutlass cruiser wagon? The 1982 cruiser wagon is a 4 head light system, and the 1978 - 80 is a 2 head light system.
I know that this has been covered in a general way in the past, but I cannot find a direct answer to this question.
Thanks everybody for your help.
Andy
Re: 1978-80 cutlass cruiser header panel on 1982 cutlass cru
Post by LS6 Tommy » Thu Jan 22, 2015 8:35 pm
AFAIK, the header panel is a swap, but you will probably have to modify the radiator support to fit the 4 headlight setup.
Longroof79
Post by Longroof79 » Fri Jul 17, 2015 9:16 pm
Tommy,
He's looking to put a dual headlight header panel on a quad headlight car. So he should have no problem bolting on the dual headlight header panel. No modification necessary.
Jack
'79 Malibu wagon, mild 355 sbc, TH350, 8.5 GN rear, 3.08 hwy gears..going thru a transformation.
Updates include new A/C, built 200-4R trans, 3.42 gears, tinted glass, etc.
Post by LS6 Tommy » Sat Jul 18, 2015 11:08 pm
Longroof79 wrote:Tommy,
Cool. Maybe I was thinking of guys that used 78-81 rad supports with 82+ headers that had to cut the headlight buckets a little.
Post Reply
