A pillar sealer
Autobody and Paint Tech Discussion
Moderator: Moderators
Post Reply
78elk
A pillar sealer
Post by 78elk » Mon Oct 12, 2015 10:15 am
What is the best sealer to use on the A pillar? What is the best sealer to use around the hinge bolts?
melloelky
Re: A pillar sealer
Post by melloelky » Mon Oct 12, 2015 8:49 pm
I'm not positive but i think it was seam sealer around the hinges from the factory.all i remember was it was cracked and falling off.guessing it was a lacquer based also.i could be wrong.if i was gonna use something that wasn't going to get hard and crack if i adjusted the hinges/doors I'd go with a version of 3m's strip caulk.there's cheaper versions of it out there too but that's the most popular. it's a sealer that that doesn't get hard it stays pliable so you can work it into different areas.comes in 12" lengths and is very easy to use
rotisserie-mod
82 el camino
406/200r4
78elk
Re: A pillar sealer
Post by 78elk » Tue Oct 13, 2015 7:20 am
Thanks. I'll check that out.
1981Regal
Re: A pillar sealer
Post by 1981Regal » Tue Oct 13, 2015 8:21 am
http://3mcollision.com/products/sealant ... black.html" onclick="window.open(this.href);return false;
http://3mcollision.com/products/sealant ... k-550.html" onclick="window.open(this.href);return false;
1980 Malibu coupe 468/th350
78elk
Re: A pillar sealer
Post by 78elk » Tue Oct 13, 2015 5:37 pm
Thanks. I'll look into those products.
Contact:
Re: A pillar sealer
Post by Doober » Tue Oct 13, 2015 6:48 pm
I used the strip caulk around my heater box, sticky stuff.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
78elk
Re: A pillar sealer
Post by 78elk » Wed Oct 14, 2015 1:16 pm
Thanks. Good ideas.
Post Reply
