Just Disgusted With Rust-Oleum Spray Paint (rant)
Moderator: Moderators
Post Reply
malicad
Post by malicad » Tue Jul 19, 2016 7:07 pm
Never again will I purchase any of this crap. I just finished a project piece (aluminum), and pained it with Rust-Oleum's 2X paint. I media blasted the piece to make sure it had good tooth. Wiped it down with Duplicolor's wax and grease remover. Used their 2X black primer TO THE LETTER and when it was dry (according to the instructions) wet sanded to give a better finished product (400 grit). Topcoated with their semi gloss black following EXACTLY the time specified for any additional coats. Not rocket science here. Here's the thing...waited 2 weeks for the part to dry (harden) and assembled the piece today. When I was handling it, I noticed a small scratch what would be completely visible when installed, so I "tested" scratching another spot that wouldn't be. Left marks. When I previously used Rust-Oleum's paint from a can (quarts) to paint my floorpan after they were welded in to my Malibu, it literally took about 7 months for it to harden to the point where my nails wouldn't leave marks. I'm so sick of this company's products. I will never use anything Rust-Oleum again. Now, I have to completely disassemble my dashboard, de-solder a ton of connectors, and probably have the piece powdercoated instead of painted. Does anybody know of a GOOD spray paint that actually hardens and looks good? Valspar, Krylon?? What do you use?? Thanks!! ](*,)
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
Mike
Re: Just Disgusted With Rust-Oleum Spray Paint (rant)
Post by Mike » Mon Jul 25, 2016 7:00 pm
Once the VOC laws came into play the rattle can paints turned to junk. When I redid the front end of my wagon I used SEM Hot Rod Black on almost everything. I also used Duplicolor engine enamel on some of the smaller detailed parts like tie rod ends, pittman arm and shocks. EVERYTHING painted with that paint has rusted. I have to redo all of it the minute the car comes back from the body shop. I hate doing things twice.
Post by LS6 Tommy » Tue Jul 26, 2016 4:25 pm
I'm confused. You say you're disgusted with Rustoleum, but then tell us how you used Duplicolor's products...
1981Regal
Post by 1981Regal » Tue Jul 26, 2016 4:42 pm
They the same paint or both equally bad paint products?
1980 Malibu coupe 468/th350
Ed Cannon
Post by Ed Cannon » Tue Jul 26, 2016 5:21 pm
The brush on hammertone stuff is tough and doesn't leave brush marks when properly applied. Used it on my roll bar.
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
malicad
Post by malicad » Sun Jul 31, 2016 2:57 pm
LS6 Tommy wrote:I'm confused. You say you're disgusted with Rustoleum, but then tell us how you used Duplicolor's products...
??? I said I used Duplicolor's wax and grease remover, which is basically acetone. I don't use Duplicolor's paints...learned my lesson there, too. Painted numerous engines with that stuff, and while it covers well and looks nice, there is no lasting quality there. I wonder why those car shows on Spike (Muscle Car and Detroit Muscle) use a ton of Duplicolor products. Go see those cars after a couple years. Paint will probably be peeling.
1981Regal
Post by 1981Regal » Sun Jul 31, 2016 8:59 pm
Hmm I just thought that's what they do peel and crack. I've never had any engine paint last unless it just sits like a museum piece.
malicad
Post by malicad » Mon Aug 01, 2016 10:43 am
:lol:
I've heard of people using actual automotive paint (2 part) for engines. Would that stuff actually hold up to high temps like that? If that's the case, Eastwood has those 2K rattle cans for around 20 bucks each that is as good as paint from a professional gun (so they say).
Post by LS6 Tommy » Mon Aug 01, 2016 12:53 pm
I got thrown off by your statement "Wiped it down with Duplicolor's wax and grease remover. Used their 2X black primer TO THE LETTER and when it was dry (according to the instructions) wet sanded to give a better finished product (400 grit). Topcoated with their semi gloss black following EXACTLY the time specified for any additional coats."
I understand what you meant now.
81classic
Post by 81classic » Tue Aug 09, 2016 2:24 pm
malicad wrote::lol:
sprayed my engine with single stage paint to match the color of my car. Still holding up since 2012
81 Malibu - Frame off restoration
05 GMC Sierra Denal 6.0l AWD
Cliff C.
malicad
Post by malicad » Tue Aug 09, 2016 4:24 pm
Ed Cannon wrote:The brush on hammertone stuff is tough and doesn't leave brush marks when properly applied. Used it on my roll bar.
I did actually use this on my transmission crossmember and it held up great.
81classic....thanks for the tip. I might try that on my next engine build (if I do one).
malibuguy
Post by malibuguy » Wed Aug 10, 2016 3:25 pm
Next time heating the piece?
I always have better luck with heating the piece somewhat to 'bake' it on
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
malicad
Post by malicad » Wed Aug 10, 2016 6:12 pm
I could've done that, to make sure it cured, but I hung it for literally 2 weeks in my basement, where I have a dehumidifier going all the time. 72 degrees and 40-50% humidity in my basement at all times. I thought that would be long enough. I ended up finding an awesome place that does powder coating very reasonably. 20 bucks later, it looks awesome and will never chip or scratch! If hindsight were 20/20, lol
malibuguy
Post by malibuguy » Thu Aug 11, 2016 5:59 pm
Powder coat is the way to go if you can swing it. I got a guy who is so darn good i cannot afford him haha
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
Post Reply
