Outty on the roof from dome light screw.
Moderator: Moderators
Post Reply
montessaj
Post by montessaj » Sat Nov 29, 2008 1:53 am
How do I fix this outty on the roof? I screwed the dome light screw in too much...I don't to have to remove all the paint I was wondering if anybody had any tricks to fixing it? Thanks.
Z-man
Re: Outty on the roof from dome light screw.
Post by Z-man » Sat Nov 29, 2008 9:34 am
Do you have a PDR(paintless dent repair) shop around there? If not what I would do is drop the headliner down a bit get youself a fairly hard rubber malet and a dolly or body spoon (whatever you can get on the back side of it), and work it down don't wail on it or you will strech the roof, soft taps is all you need. That will make it look better but the only way to get the roof flat agatin is to open up the paint and do body work.
Darren
The fastest malibu in Barnesville MN.
78 Malibu Landau, 81 Malibu four door, 97 Silverado Z-71
Post Reply
