Can I use a fiberglass hood with factory hinges?
83LSWagon
592
Spring Hill, FL
My dad says no, but after that he added "but it's been a long time since I've looked into it."
So can I keep the springs?
StreetBu
4,158
3
Upstate NY
Your contradicting yourself, do you mean factory hinges or factory springs, you stated both. Yes you can you factory hinges if you buy a hood meant for them, BUT you CAN'T use factory springs on ANY of them, They bow the center of the hood up and it'll look like crap.
Supe
15,116
Charlotte, NC
Leave the hinges, ditch the springs, drill the hinges in the open position and insert a quick release pin.
79izfine
2,199
massachusetts
yea what sup said i did that with mine only i used thick cotter pins work excellent
James Bond
1,359
Earth
i took the springs out, bolted it to the hinges and use a prop rod to hold it up.
BigJayDee
You can also go to the autopart store and get the gas shocks that hold up rear window hatches on some cars.
