Caliper Position Help
Questions, answers, tips and tech on wheels, tires and brake issues
Moderator: Moderators
Post Reply
80Grand_LeMans
Post by 80Grand_LeMans » Sat Nov 10, 2012 11:14 am
Really dumb question that I can't seem to find the answer on. Does the brake hose mount to the top of the caliper or the bottom of the caliper? I had them mounted so the hose would go to the top but it didnt seem like it wanted to fit very well. I swapped sides so the hose goes to the bottom of the caliper and it fits fine now (had brakes off for over a year now). Should the hose be going to the top and I have to swap it back now? Or is it not a problem if they are mounted on the opposite side? Thanks.
1980 Pontiac Grand LeMans
-Mild Olds 350, TH350, 7.5 one tire fire :(
tiedyemike8
Re: Caliper Position Help
Post by tiedyemike8 » Sat Nov 10, 2012 11:37 am
The bleeder screws should be higher than the hoses.
1989 Suburban with a 1973 front end.
1980 Monte Carlo. Used to have a 406. Will eventually have a 434.
1970 Meyer's Manx. 1679cc
80Grand_LeMans
Post by 80Grand_LeMans » Mon Nov 12, 2012 9:41 am
Thanks! swapped them around again for the third time -__- and got the hose on. Good to know I have it on the right way now
icecold
Newbie
Post by icecold » Sun Apr 10, 2016 9:07 am
tiedyemike8 wrote:The bleeder screws should be higher than the hoses.
=D>
Post Reply
