Booster leak causing increased idle speed?
Questions, answers, tips and tech on wheels, tires and brake issues
Moderator: Moderators
Post Reply
DV8
Post by DV8 » Tue Jun 20, 2006 3:09 pm
When I depress the brake pedal it causes a hiss from the booster and the engine idle increases a couple/few hundred rpm.
I just installed ALL new brake lines & hoses (rust damage & age) and everything bled out nicely with a real good pedal. The booster seems to be working ok, pedal is not heavy.
I've had boosters fail before, but they always gave a real heavy pedal and killed the engine......
People who think that life is anything more than pure entertainment are missing the point.
http://www.cadillacpower.com/forum/inde ... &g2_page=4
81classic
Post by 81classic » Tue Jun 20, 2006 3:30 pm
thats generally what happens when you get a vacume leak
81 Malibu - Frame off restoration
05 GMC Sierra Denal 6.0l AWD
Cliff C.
JRodS79
Post by JRodS79 » Tue Jun 20, 2006 3:43 pm
it may be about to let go but if you pump any booster fast it will increase idle. it may have a small vac leak and making it hard to come back to idle
81 grandma edition. project Social Security Budget
dated wheels, f41 front bar, rear sway bar
disgusting amount of HP from the electric 2bbl v6
Supe
Pro Moderator
Post by Supe » Tue Jun 20, 2006 10:55 pm
Probably a pinhole leak.
Don't leave home without your Umbrella
DV8
Post by DV8 » Wed Jun 21, 2006 8:00 am
Well guys, did some more screwing around with the heap, and found the problem.
Under the dash, below the brake light switch, is another switch w/ a purple wire and a pink w/black tracer wire, AND A VACUUM LINE attached. I don't know what this is for exactly, but when the switch is activated (when the pedal is depressed) the switch starts leaking vacuum and the idle increases. No idea where the wires go (they dissappear into the harness) but the hose is connected to a T in the PCV hose.
This car was originally a diesel, had a truck 350 swapped in before I got it, but no sign of a hydraboost. Also has what might be aftermarket cruise on it? Car has buckets/console, PW PL PS PB.
I put visegrips on the hose, and no hiss and no idle change. But what is this switch for?
WEBBER
Post by WEBBER » Wed Jun 21, 2006 10:27 am
That switch would be for the cruise control. It kicks the cruise off when you hit the brakes.
The older I get, the more dangerous, I am !!!!
The only replacement for cubic inches, is rectangular dollar$$$$$$
Post Reply
