mechanical injection
78_Elky
1,680
Oregon
smlblk78.onlineshowoff.com
Haven't used it personally, but from what I've heard it is hard to tune for street use. I think it is very well suited for WOT like at the strip, but driving around town can be really hard to get right.
-Josh
im building a bracket car so im not concerned with drivability. from what ive read, they are supposed to be easier to tune than a holley, but i was just wondering how they compared as far as power. didnt know if it was worth spending the money vs a carb. thanks
540Malibu
1,432
Shrews., MA
mech. will make more power providing its tuned properly, the spray mist of alky cools better too.
"Myth Busted" ;)
FI, whether electronic or mechanical, does NOT in itself make more peak power than the same combo would with a properly setup carb system. It MAY have a little bit better drivebility and in the case of electronic systems more consistancy and broader tuning parameters.
x2 ...but only as far as EFI is concerned. its just a more precise way of doing everything a carb does... + self adjusting to all atmospheric conditions... the big advantage of efi is when you use systems that you can adjust the spark curve... timing = power, without timing control, you're just wasting money(why mechanical inj is kinda pointless)...as far as power, i've built several efi systems recently now for my buddies an i using a dfi controllerand have definately picked up a few hp on the dyno (no miracles, 12 hp on a 355 street motor we settup nothing too crazy), along with a broader power band... as far as drivability, i definately get better cold start drivability and better mileage. mechanical injection is a waste of time imo compared to a carb... go efi or keep the carb if it does it for you...
1QwikBu
1,387
olympia washington
LS6 Tommy said:
"Myth Busted" ;)
i beg to differ there is a certain blue tt camaro that went from carb to fi and dropped 3 tenth's first time out ... i also know of 2 other racers one went from carb to a rons toilet and dropped 3 tenths the other went from farb to efi and dropped even more in et and these guys were diehard carb guru's for years and years
1QwikBu said:
LS6 Tommy said:
"Myth Busted" ;)
this is the kind of stuff i have HEARD. just didnt know if anyone had any personal experience. one of rons systems is a lot more$ than a carb so there has to be some way to justify the cost.
stew6371 said:
1QwikBu said:
LS6 Tommy said:
"Myth Busted" ;)
You have "heard" it and I have been there. I've seen dyno runs out he wazoo. I stand by my statement. "Myth Busted." Airflow is airflow. Fuel demand is fuel demand. In terms of straight out fuel metering based on airflow needs a carb will offer no less peak power than a FI system. Even FI companies (that are honset) will agree. A tenth or two here and thereris nothing more than driver error.
A tenth or two here and therer is nothing more than driver error
...or better air
