Search:
1. Locate a donor car with RKE. The RPO code on the SPID label on the underside of the trunk is AU0. The module is INSIDE the car just to the right of the right rear speaker UNDER the package tray carpet. It's attached with Velcro so just pull it off. Disconnect the connector and push it into the trunk.
2. Go inside the trunk and pull down on the harness. There is a programming connector that is taped on the taillight harness just under the carpet on the right of the trunk. Split open the harness wrap and try to keep this wire in one piece. Give yourself 12 to 18 inches of wire and cut the harness connector out of the trunk. More wont hurt if you can pull it to you. My module and harness cost me just under $25 without the key fob. They were no where to be found in anything on the yard.
Install:
1. Almost every connection can be made at the Right Front kick panel where the door lock relay is located. I spliced my wires with butt connectors because I hate a Scotch Lock. If you look close at the module connector, you will see letters that label the cavities in the connector. I'll list them by letter, color, function, where to splice (SP-)
A. Tan, not used (I'll explain why later)
B. White, unlock control to relay, SP- Black wire on Lock relay
C. none
D. none
E. Orange, Batt +, SP- Orange/Black wire on Lock relay
F. Light Green, Trunk release, SP- Pink wire on trunk switch
G. Gray, Trunk release, SP- Black wire on switch
H. Black/White, not used
J. Pink, Switched IGN voltage, Run to fuse block to a Switched IGN source
K. none
L. Black/White (smaller gauge than H), programming connector
M. none
N. Black, Ground, add ring terminal and ground under screw for relay
P. none
R. Light Blue, lock control to relay, SP- Light Blue wire on Lock relay
S. Dark Blue, Illuminated entry (interior lamp control), SP- White wire from door jamb switch
Your colors should be the same except for maybe the trunk release. Mine was an add-on but check your power at the switch with a test light. F is power into the module and G is power to the trunk Solenoid.
2. After all connections are made, test the system. Attach a ground wire to the programming connector and the locks and trunk should cycle. If not, go back and check your connections.
3. Locate your remote. Part numbers: 16245103, 16207901, 16207903 are listed as correct for the module I used. There may be others. With the programming connector still grounded, hold down LOCK and UNLOCK until the locks cycle again (may take up to 30 sec). Do this for all the remotes you want to add (one after another, up to 4). Remove the ground and test.
One press of the UNLOCK should turn on the interior lights. A second press should unlock all doors. The LOCK and TRUNK functions should be pretty straight forward. The TAN wire we didnt use is for cars where the Left front door is wired separate from the others. This would allow for the first press to just unlock the Left front door and turn on the lights. I didnt want to cut more wires and run them elsewhere so one press works the lights only.
4. Wrap up the wiring and zip-tie the module up behind the dash next to the AC vent. My range is at least 30 feet in an open yard.
If you have any questions, comments or corrections, let me know and I'll try to help.
Mess of Wires by Relay:
Module
Key Fob:
Connector Pics:
Wiring Diagrams:
Malibu
Lumina
