how to wire relays
Discuss all electrical and wiring issues here.
Moderator: Moderators
gmachinz
Re: how to wire relays
Post by gmachinz » Sat Aug 23, 2008 7:19 pm
I'll post some pics of the fuse/relay center I'm incorporating into a 1966 Chevelle I'm building at my shop. I removed the entire relay center from a 99 Olds Alero and it has a total of 10 realys, some of which are 5 pin as well as about 12 MAXI style fuses-it looks factory and it provides an easy place for proper wire routing. -Jabin
gmachinz
Post by gmachinz » Sat Aug 23, 2008 11:46 pm
http://www.pro-touring.com/forum/showthread.php?t=46075" onclick="window.open(this.href);return false;
My images appear to be too big-here's the Chevelle I'm building at the shop. It's a dynoed 632 hp 406 mechanical roller motor with an NX kit that's capable of adding approx. 750 hp more. You can see the relay center I'm building for it-that is how I build my electrical systems underhood. The MAXI style fuses handle current loads better and the integrated relays keep everything neat and tidy. I'm still in the middle of running all the electrical for it at the moment.
HarrisonTX
Contact:
Post by HarrisonTX » Tue Nov 04, 2008 8:42 am
I am taking the adive of ordering quality relays.
Does anyone know where i can get a Potter & Brumfield or bosch relay? Im restricted to ordering online
79 coupe
406CI w/ TrickFlow twisted wedge heads
TKO500
9'' rear with spooled 3.89
Chrome wont get ya home
Robert1320
Post by Robert1320 » Tue Nov 04, 2008 1:20 pm
CDR Performance
The Custom Engine Shop
Official Sponsor of the first Annual
YellowBullet.com Nationals
BMR Sales
MalibuRacing Authorized Advertiser
Post by BMR Sales » Fri Nov 21, 2008 11:32 am
HarrisonTX wrote:I am taking the adive of ordering quality relays.
Sometimes if there is a "good" parts guy at your local parts store they can find relays for you. Just ask them to bring the box with the relays in it from the back and even though GP or Wells name is on the box open them up and look at the back of the relay. Most of the time you will find Bosch relays in the boxes or you might get lucky and find Hella relays there as well.
BMR Suspension Sales
http://www.bmrsuspension.com
813-986-9302
Excelerater
Post by Excelerater » Tue Feb 03, 2009 6:05 pm
how do you wire 2 relays in paralell?
I am a dealer for TRZ Motorsports ,PM me for your suspension needs....
We'll get you hooked up
ILLEGAL REGAL
Post by ILLEGAL REGAL » Tue Feb 03, 2009 8:30 pm
why run 2?
Excelerater
Post by Excelerater » Wed Feb 04, 2009 6:42 am
ILLEGAL REGAL™ wrote:why run 2?
big pumps use big power.....
also,incase one dies on ya
ILLEGAL REGAL
Post by ILLEGAL REGAL » Wed Feb 04, 2009 4:49 pm
the reason they say run 2 is simply in case 1 fails there's a backup.. and thats words directly from them.
Excelerater
Post by Excelerater » Thu Feb 05, 2009 8:33 am
The only thing bad about that idea is :
If one relay went bad how would you ever know??????
I dont know why they just dont sell /use a 70A relay like this
http://order.waytekwire.com/productdeta ... R%20RELAY/" onclick="window.open(this.href);return false;
ILLEGAL REGAL
Post by ILLEGAL REGAL » Thu Feb 05, 2009 6:51 pm
I guess when the 2nd goes bad :mrgreen: I'll use a single and carry a spare
slimbo
Post by slimbo » Fri Oct 30, 2009 12:06 pm
i run redundant raleays for my pump as well. i use ihc hydroboost relays. they have a sweet sealed socket.
they are on the right fenderwell next to my msd box.
pump gas,3880 pound,9.43@141.8 1.24 60 foot, not your grandmas gp
2012 hot rod magazine drag week,3rd place small block power adder
You'd give it all up for what's there for the taking
Whatever it takes to keep your hands from shaking
The same things you're thinking might make you feel better
The same things that probably got you here
BMR Sales
Post by BMR Sales » Wed Nov 04, 2009 8:15 am
Man those look nice, where'd you pick them up from?
813-986-9302
cttandy
Contact:
Post by cttandy » Wed Nov 04, 2009 5:51 pm
While I was working at the salvage yard, we had an ambulance come in. I dug around until I found the relay panel.
I know have about 60 - 50 amp relays and as many 50 amp breakers.
I have used them for all sorts of stuff over the last few years.
Your rationality will never compare to the level of my idiocy
NO LONGER A MALIBU OWNER
94 GMC Suburban My build thread
Post Reply
