Discuss all electrical and wiring issues here.
Moderator: Moderators
MyBU
- Frequent Racer
Post
by MyBU » Sun Sep 02, 2007 5:58 pm
Im getting annoyed with the blower motor in my car. When I bought the car, The red, green, and dark green wire hookup on the A/C box wasnt connected. So I fix the plug and connected them together. I go underneath the dash, and there was no fuse for the blower motor. I put one in.
It turned on, but it only worked for about 30 min. WTF! The 25amp fuse blew! I put a 30amp fuse in. It worked for another 30 min and the fuse blows again.
Could someone please help????
Im desperate!!!!!
TURNA
- MalibuRacing Junkie
Post
by TURNA » Sun Sep 02, 2007 7:25 pm
put a penny in the fuse pannel
if it blows that you in big troble!!
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
WEBBER
- Pro Stocker
Post
by WEBBER » Mon Sep 03, 2007 9:07 pm
On that harness you talked about, there's another connector up by the carburetor, on the pass side. Pull it apart and look in there, you'll probably see it is corroded.
The older I get, the more dangerous, I am !!!!
The only replacement for cubic inches, is rectangular dollar$$$$$$
MyBU
- Frequent Racer
Post
by MyBU » Tue Sep 04, 2007 12:47 pm
WEBBER wrote:On that harness you talked about, there's another connector up by the carburetor, on the pass side. Pull it apart and look in there, you'll probably see it is corroded.
What colors are the wires and how many of them are there in the connector your talking about?
Thanks
MyBU
- Frequent Racer
Post
TURNA wrote:put a penny in the fuse pannel
WEBBER
- Pro Stocker
Post
by WEBBER » Tue Sep 04, 2007 5:55 pm
Three wires light green, dark green, and red. Also your blower fan switch might be going bad, check it out.
MyBU
- Frequent Racer
Post
by MyBU » Tue Sep 04, 2007 6:37 pm
WEBBER wrote:Three wires light green, dark green, and red. Also your blower fan switch might be going bad, check it out.
Alright, im going to try that out. Thanks
MyBU
- Frequent Racer
Post
by MyBU » Wed Sep 12, 2007 11:00 am
Well, I tried everything. I cleaned the contact points in the plug, replaced the relay looking thing on the box, replaced the other little switch that mounts inside the box with the coiled springs on the bottom of it.
ITS STILL BLOWING FUSES!!!!!
None of the wiring looks damaged to me!!
TURNA
Post
by TURNA » Wed Sep 12, 2007 11:09 am
just do what i said and shove a penny in where the fuze goes!!!!
81Bu2Dr
Post
by 81Bu2Dr » Wed Sep 12, 2007 11:32 am
MyBU wrote:Well, I tried everything. I cleaned the contact points in the plug, replaced the relay looking thing on the box, replaced the other little switch that mounts inside the box with the coiled springs on the bottom of it.
Just remember...if you are blowing fuses...you are drawing too much current (you have a short somewhere). Be looking for burnt wiring, a nick in the wiring jackets. It's there somewhere, and it does not take much to short out. Better to be blowing fuses than going up in flames.
slimbo
- Moderator
Post
by slimbo » Thu Sep 13, 2007 2:54 am
or a shorted blower motor itself.
pump gas,3880 pound,9.43@141.8 1.24 60 foot, not your grandmas gp
2012 hot rod magazine drag week,3rd place small block power adder
You'd give it all up for what's there for the taking
Whatever it takes to keep your hands from shaking
The same things you're thinking might make you feel better
The same things that probably got you here
- Moderator
Post
by Doober » Thu Sep 13, 2007 8:25 am
Ya, disconnect it and see if it still blows fuses, that should tell you pretty quick whether it's the wiring or motor.
MyBU
- Frequent Racer
Post
by MyBU » Sat Nov 24, 2007 9:02 pm
HA! I finally got my blower motor to work!!
It turns out that my old blower was bad, and I went to the boneyard, and pull another blower motor off a Camino.
Thanks for all the help guys and I apologize for the really, really late response.
Thanks again.
