Radiator and mount
Swap and other information about GM's LSx series engines
Moderator: Moderators
Post Reply
Jared Pennington
Radiator and mount
Post by Jared Pennington » Mon Aug 01, 2016 10:46 am
I have a 5.3 going in a '83 Malibu Wagon and I'm looking for the simplest solution on a radiator and mounting system. It will be EFI and I'll need room for the air intake. What is everyone using to solve this issue?
Kevin Williams
Re: Radiator and mount
Post by Kevin Williams » Tue Aug 02, 2016 9:17 pm
Stock V8 radiator for the g-body. It will install in the stock location. As for mounting you can use the factory shroud with trimming. That will give lots of room. I was able to find a radiator mounting plate from a turbo buick. That was years ago, good luck locating one.
87 LS Monte Carlo,
GM LS 6.0
222/232, 595/575 lift, 114 LSA, Comp Hydr Roller
Victor Jr, Demon 750
150 hp Elderbrock plate
1 3/4 Pacestter headers, 2 1/2 40 series Flowmasters
Th-350, ACC 10 inch converter
3.73 GN rearend
255/50/16 Drag Radials
Jared Pennington
Post by Jared Pennington » Wed Aug 03, 2016 8:30 am
Thank you Kevin. Much appreciated
1981Regal
Post by 1981Regal » Wed Aug 03, 2016 9:04 am
One of the gbodies has a metal radiator top plate just can't remember what one. Think it was Olds or Pontiac
1980 Malibu coupe 468/th350
thunder938
Post by thunder938 » Wed Aug 03, 2016 12:39 pm
The same rad that was in the car with SBC.
[URL=http://s1275.photobucket.com/user/ ... .jpg[/img][/url]
Jared Pennington
Post by Jared Pennington » Thu Aug 04, 2016 11:46 am
Thunder, I had a V6 in it. I'm assuming that a stock V8 replacement radiator will work? What mounting plate is yours off of?
thunder938
Post by thunder938 » Fri Aug 05, 2016 7:45 am
My rad. is just a alum. V8 unit that was in the car before, I have a doulbe elc. fan set up and a ton of room between the rad and motor. I have 1 inch set back plates on the motor mounts, I am running a th400.
Post Reply
