6.0 motor and tranny are in!!! - NOW A STICKY
Swap and other information about GM's LSx series engines
Moderator: Moderators
MetricBoo
Re: 6.0 motor and tranny are in!!! - NOW A STICKY
Post by MetricBoo » Thu Jan 17, 2013 2:22 pm
What exactly did you change (changed heads, intake, carb, and transmission (went with a transbrake) to try and run a 9?
How much of a shot were you using?
Thnx.
Roller406Bu
Post by Roller406Bu » Thu Jan 17, 2013 4:33 pm
MetricBoo wrote:What exactly did you change (changed heads, intake, carb, and transmission (went with a transbrake) to try and run a 9?
Thnx.
Yes I changed all that you mentioned and a new yank 3600 nitrous convertor.. 150 edelbrock plate
1978 Malibu, carbed 6.0, MS4 cam, trickflow 220's, Edelbrock Plate....
2002 Transam WS-6 G5x3, fast 90, 4.30's, Speed-density tuned
1986 Mustang GT
MetricBoo
Post by MetricBoo » Fri Jan 18, 2013 3:56 pm
Sorry I should have been more specific.
-What carb did you have and what do have now (cfm/model)
-What model trans are you running ( PG, th-350, 4L80E)
-What intake? I see your using TFS 220's which are cathedral port I thnk?
I'm just curious as this is simliar to my combo.
Thanks,
Roller406Bu
Post by Roller406Bu » Fri Jan 18, 2013 4:16 pm
MetricBoo wrote:Sorry I should have been more specific.
Thanks,
317 heads to as cast 220's TF
750 dp holley to a 950 quickfuel
350 turbo to a 400 turbo
victor jr to a super victor and yes cathedral...
1 3/4 headers 3inch collector to 1 7/8 with 3.5 collector as well
1986 Mustang GT
MetricBoo
Post by MetricBoo » Sun Jan 20, 2013 9:54 pm
Did you make any motor passes with the new parts before the diff let go?
What diff did you have?
Bad Ass Car, very very clean!
Roller406Bu
Post by Roller406Bu » Sun Jan 20, 2013 10:51 pm
MetricBoo wrote:Did you make any motor passes with the new parts before the diff let go?
Bad ### Car, very very clean!
yes picked up 3mph 1/8 mile track from 95 to 98.6 right off the trailor track is far away....convertor is very tight....hears the vid u can tell how it lugs it down....I'm embarrased to post a et...lol http://www.youtube.com/watch?v=FKZkCkDwbG4" onclick="window.open(this.href);return false;
car is full weight 3480 before the cage don't know what it weighs now...it wasnt a nodular center...i have a new moser nodular center in it now should be okay...thanks..
1986 Mustang GT
Hy82e
Newbie
Post by Hy82e » Wed Feb 20, 2013 3:57 pm
What are you using for the front suspension? Do you have it set up as a drag car?
I'm building a street/daily car. Full suspension, sway, bracing, AC. I'm trying to get an idea of spring rate for the car since I will not know the front end weight of the car until its all put back together, and I hate the idea of doing front springs more than once.
Roller406Bu
Post by Roller406Bu » Sun Mar 03, 2013 12:27 pm
Hy82e wrote:What are you using for the front suspension? Do you have it set up as a drag car?
qa1 coilovers with a 350 pound spring...its a street car 80% of the time but is set up for drag....no sway bars....full weight car 400 wouldn't be out of the question i had to crank and crank on the spring perch to get the front end up on mine with the 350...
1986 Mustang GT
82dragonwagon
Post by 82dragonwagon » Sun Apr 28, 2013 7:47 am
what headers are you using with this swap? I think I'm going to nix the turbo and pull out the 4.8 and do a 6.0 w/l92 heads and holley highram intake and comp cams.
82 malibu wagon with 6.0 l92 ported heads (flowed 356 cfm @ .600 lift), Holley Hi Ram l92 intake w/90mm tb, comp cams .604-.617 lift, 224-233 duration on 112 lsa, TEA .650 dual springs, Hedman Coated Long Tubes.8.8 ford w/3.27 gears. Vision 17x7 and 18x8.5 wheels w/Cooper Rs3 tires. Pulled in front and rear bumpers, Monochrome blue paint, steel cowl hood.
http://carphotos.cardomain.com/images/0 ... _large.jpg" onclick="window.open(this.href);return false;
MetricBoo
Post by MetricBoo » Fri May 24, 2013 9:38 am
Have you been able to get back to the track with the new diff?
82dragonwagon
Post by 82dragonwagon » Wed Jun 26, 2013 7:58 pm
what are you running for a fuel pump?
Roller406Bu
Post by Roller406Bu » Wed Jun 26, 2013 9:11 pm
82dragonwagon wrote:what are you running for a fuel pump?
2 Holley blue pumps
1986 Mustang GT
82dragonwagon
Post by 82dragonwagon » Thu Jun 27, 2013 6:31 am
I think I'll have to change mine to a walbro in tank for my upgrade to the 6.0. I'm taking my l92 heads to the porter today. .
MetricBoo
Post by MetricBoo » Sun Sep 08, 2013 9:04 am
Any track time updates?
Roller406Bu
Post by Roller406Bu » Sun Aug 17, 2014 7:54 pm
outside..haven't raced the car in over a year.. going to get the suspension dialed in for better sixties.
went a 6.48 @108.5 1.52 last
https://www.youtube.com/watch?v=-aAian2 ... PowqR4UBTQ" onclick="window.open(this.href);return false;
go pro
https://www.youtube.com/watch?v=VDG3HRO ... PowqR4UBTQ" onclick="window.open(this.href);return false;
1986 Mustang GT
Post Reply
