clutch pedal
Swap and other information about GM's LSx series engines
Moderator: Moderators
80bu
clutch pedal
Post by 80bu » Thu Jun 11, 2009 6:13 pm
Does anyone no of somebody that makes clutch pedals for malibu's with a ls t-56? I have contacted John b and he can't do one till January. Thanks for the help
1980 Malibu
Ls1 T56, Money well spent!!!
Garage Hound
Re: clutch pedal
Post by Garage Hound » Fri Jun 12, 2009 12:32 pm
Hey David, are you going manual?
1980 Malibu
355 SBC w/ all-forged rotating assembly (Eagle)
Trick Flow 195cc heads
Lunati cam: .517/.543 @ 278/288 degrees
Weiand intake
Holley 750
TH350 w/ 3500 stall
Bone stock rear just waiting to explode!
It was a blast while it lasted but going fast isn't cheap.
Out of the sport due to lack of funding and the sale my local racetrack (KCIR)
Jay
80bu
Re: clutch pedal
Post by 80bu » Fri Jun 12, 2009 1:19 pm
Yes I am six speed, but I am not sure on the clutch pedal setup.
1980 Malibu
83LSWagon
Re: clutch pedal
Post by 83LSWagon » Fri Jun 12, 2009 1:21 pm
Cant just run g-body pedals? Think I saw em on ebay before
back it outside and do a burnout till the axle,tire,brake line and brakes come off the passenger side of the car. get out, throw your arms up in the air and start chanting "im awesome".
blubaldmontess
Re: clutch pedal
Post by blubaldmontess » Fri Jun 12, 2009 3:08 pm
john b, or john s, but I believe john b on montecarloss.com here is his homepage, he makes the ones to do the t56 swap into the g body, and everybody i've heard that gets em loves em.....
http://www.montecarloss.com/ls1montecarloss/
When I was growing up, cars were lowered and trucks were lifted...Now cars are lifted and trucks are lowered...what did I miss and when??
80bu
Re: clutch pedal
Post by 80bu » Fri Jun 12, 2009 4:36 pm
John b is in italy till January, so that's why i need other options
1980 Malibu
dyrt
Re: clutch pedal
Post by dyrt » Sat Jun 13, 2009 9:00 am
if you need one now, your best bet is probably to find a set of originals somewhere(i heard of some people having problems with the aftermarket ones but someone might want to chime in on that) and weld a tab from a set of f-body pedals on. The f-body pedals, if i remember correctly, actually had the tab welded on from the factory, so a die grinder and some patience, a little bit of welding, etc, you should be golden. I would give you the dimensions for where the stud should be in relation to the top pivot but there is no way i can get that pedal out of the car to measure. Anyone have one handy that can give some measurements? Also, make sure you fab up a pedal stop for yourself and some pedal to firewall bracing no matter which route you take so you don't run into clutch master cylinder and firewall flex problems.
1986 regal limited, '95 lt1, t56,ram hdx clutch,hurst short throw, hooker shorties, '96 TA buckets, canteen metallic paint, ls1 brakes, gn rear w/3.73s, custom gauge cluster,95 trans am calibration.
Re: clutch pedal
Post by Doober » Sat Jun 13, 2009 12:07 pm
John Bzdel outlines trying a stock pedal setup in his buildup of the Monte, and everything he had to do to make a pedal work.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
blubaldmontess
Re: clutch pedal
Post by blubaldmontess » Sat Jun 13, 2009 2:37 pm
How about Bernie, I'm sure he has a template laying around as well...he's sickspeedmonte over there, and here I believe...hth
80bu
Re: clutch pedal
Post by 80bu » Sat Jun 13, 2009 6:46 pm
I am gonna see if i can have a local guy just fabricate the f-body one to my pedal setup.
1980 Malibu
Jackstand
Re: clutch pedal
Post by Jackstand » Thu Jun 18, 2009 3:10 am
im keep forgetting to check.. i just put a reminder in my phone to do it today
80bu
Re: clutch pedal
Post by 80bu » Fri Jun 19, 2009 9:22 pm
Thanks
1980 Malibu
BAD78BU
Contact:
Re: clutch pedal
Post by BAD78BU » Mon Jul 30, 2012 10:45 pm
80bu wrote:Does anyone no of somebody that makes clutch pedals for malibu's with a ls t-56? I have contacted John b and he can't do one till January. Thanks for the help
http://gsi-interiorss.com/item/monte-ca ... lid=983837" onclick="window.open(this.href);return false;
Go here cheap pedal assy. for gbody conversion
"1978 Malibu Classic still under construction, will soon have an 6.0L/T56 combo onboard!"
Re: clutch pedal
Post by t5montecarlo » Tue Jul 31, 2012 8:49 pm
SEVNT 9 reworked John's pedal due to geometry issues. He must have changed his photo host folders because the pictures don't resolve anymore.
http://maliburacing.com/forum/viewtopic ... 2&p=852586" onclick="window.open(this.href);return false;
The GSI pedal looks like John's.
80bu
Re: clutch pedal
Post by 80bu » Fri Aug 03, 2012 8:51 pm
I used the GSI pedal, worked out great!!!!
1980 Malibu
Post Reply
