86 4.3 fi converted to carb set up info wanted
Info and tech for V6 engines
Moderator: Moderators
Post Reply
79izfine
Contact:
Post by 79izfine » Wed Apr 25, 2012 5:11 am
my plan is to do this least expensive for what i want ,,,my plan is to go with a 4 barrel carb ,,, clearly the intake , carb,,distributor and i believe the cam needs to be changed is there anything i am missing ,,,, the block has provisions for a mech fuel pump ,,,, the fi fuel system has already been converted to mech pump so im good there ,,,,, also are there intakes availeable for the 86 4.3 thanks
Contact:
Re: 86 4.3 fi converted to carb set up info wanted
Post by Doober » Wed Apr 25, 2012 1:52 pm
Sounds like everything's covered, I don't know if the cam has a mechanical lobe, otherwise it would just be intake/carb/distributor swap. Why are you going to carb? What's this for?
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
clean8485
Post by clean8485 » Wed Apr 25, 2012 7:27 pm
GM produced a 4.3 V6 with a 4 barrel carburetor for their light duty trucks in 1985 and 1986. The carbed engines were used in light duty full size pickups and Astro and Safari vans. Those engines are getting kind of rare these days though. There are aftermarket 4 barrel intakes available for the 4.3, but they're not emission compatible though (no provision for EGR). As Doober said, what kind of project are you working on?
79izfine
Contact:
Post by 79izfine » Thu Apr 26, 2012 5:22 am
not sure what motor will be used for i just have it on a stand and is a good running motor ,,,for me its easier to deal with a carb'd motor than tbi etc ,,,,just seeking info for future use maybe it will go back in the monte or i have a model A frame i want to start building and thought the 4.3 would be good for that
Contact:
Post by Doober » Thu Apr 26, 2012 11:32 am
If you can find a good set of real ('96+) Vortec heads at a junkyard & bolt a carbed intake to that with a mild cam you'll have a decent little runner :)
79izfine
Contact:
Post by 79izfine » Thu Apr 26, 2012 7:11 pm
sounds like a good idea vortec's
Post Reply
