Which BBC gen IV oil pan
Questions, answers, tips and tech on drivetrain issues.
Moderator: Moderators
Post Reply
Time Warp
Post by Time Warp » Thu Jun 08, 2017 9:55 pm
What pan are you using and how do you like the fit ? I have 2241 headers and will be using moroso solid motor mounts i think
Ed Cannon
Re: Which BBC gen IV oil pan
Post by Ed Cannon » Fri Jun 09, 2017 7:24 pm
Summit house brand 6 qt pan. Nice pan, good price perfect fit. I have 2241 headers and solid mounts. Over 400 1/4 passes in 4 years no issues.
80 Malibu. 496 pump gas.
10.09@132 N/A
6.33@109 n/a 1.38 60ft. With South Side bars!
9.75@135 100 shot.
A stupid question is better than a stupid mistake!
Time Warp
Post by Time Warp » Sat Jun 10, 2017 7:23 pm
Ed Cannon wrote:Summit house brand 6 qt pan. Nice pan, good price perfect fit. I have 2241 headers and solid mounts. Over 400 1/4 passes in 4 years no issues.
Thank you Ed ,
Do you recall if it was :
SUM-G3605 ( Pan mounted dipstick. Fits Camaro and Chevelle (A and F-body) chassis.
or
SUM-G3604
-83MONTESS-
Post by -83MONTESS- » Sun Jun 11, 2017 12:49 pm
I use a cheap 7 qt kickout pan on my 496. Got it from KMJ Performance on ebay a few years back. Fits great, doesn't leak and no issues with starter, oil filter or headers. Passenger side pan mounted dip stick.
shoedoos
Post by shoedoos » Mon Jun 12, 2017 6:43 pm
Milodon 31188 works with your headers....bit spendy though
http://www.milodon.com/oil-pans/drag-ra ... l-pans.asp" onclick="window.open(this.href);return false;
Time Warp
Post by Time Warp » Tue Jun 13, 2017 8:31 pm
-83MONTESS- Thanks , i looked at a few of these , didnt see a 7 qt one . Ill see what i can find thou
shoedoos , that is a nice pan , but out of my price range .
Ed Cannon
Post by Ed Cannon » Wed Jun 14, 2017 5:19 pm
My dipstick goes in the pan on the right side its the g3605 pan.
10.09@132 N/A
9.75@135 100 shot.
Bar50
Post by Bar50 » Sat Jun 17, 2017 1:33 pm
Most straight down BBC pans will work, as long as they are not for Corvette or Truck. I have the Milodon kick-out pan, but, I have the 2455 headers. The kick out portion will get into being a headache with the starter and oil filter.
Post by LS6 Tommy » Fri Jun 23, 2017 9:47 am
I hope my OEM pan will work. It's all sealed up nice. It fit in my '69 Chevelle SS396...
dustin72
Post by dustin72 » Tue Jul 04, 2017 12:29 am
I used the Milodon 30950. It was a nightmare to get the headers in the car with the kickouts, but once they were in, everything cleared fine.
kevind
Post by kevind » Tue Jul 04, 2017 7:38 am
I use a GM pan 70 Chevelle type also have used a Steff's pan.
80 Malibu 500" BBC,TKO 600,Moser 9",Vintage Air and a few other things.
78 Malibu 25.5 car 574" All Aluminum BBC street car.
prairiehotrodder
Post by prairiehotrodder » Tue Jul 04, 2017 10:19 am
I have a moroso 7 qt kickout pan. i use 6 qt of oil in it. Dyno shop guys have told me that running the full 7 qt costs alot of power. I also run a stock gm vortec starter. When i had the 2241 headers this pan was a pain for oil filter clearance. Now with Lemons headers its fine. The only thing i don't like about it is the location of the drain plug. If i was to buy another pan i'd make sure every last drop of oil drains out. I spent a little extra and get a 1 pc oil pan gasket and also a oil pan stud kit. I hate leaks. Allthough i have noticed that a 4.25 stroke crank will take little bites of the blue felpro 1 pc pan gasket.
Brian
What does it profit a man if he gains the whole world and loses is own soul?
http://therocketshop.blogspot.com/" onclick="window.open(this.href);return false;
bracketchev1221
Post by bracketchev1221 » Fri Jul 21, 2017 6:54 am
prairiehotrodder wrote:I have a moroso 7 qt kickout pan. i use 6 qt of oil in it. Dyno shop guys have told me that running the full 7 qt costs alot of power. I also run a stock gm vortec starter. When i had the 2241 headers this pan was a pain for oil filter clearance. Now with Lemons headers its fine. The only thing i don't like about it is the location of the drain plug. If i was to buy another pan i'd make sure every last drop of oil drains out. I spent a little extra and get a 1 pc oil pan gasket and also a oil pan stud kit. I hate leaks. Allthough i have noticed that a 4.25 stroke crank will take little bites of the blue felpro 1 pc pan gasket.
Brian
Mine gained 4 hp going from 7 qts to 6 qts.
http://s30.photobucket.com/albums/c306/ ... C01615.jpg" onclick="window.open(this.href);return false;
My old 78
http://s30.photobucket.com/albums/c306/ ... usquet.jpg" onclick="window.open(this.href);return false;
Post Reply
