UMI Performance New Product- Pro Style Rear Sway Bar
UMI Performance
233
Bigler, Pa
www.umiperformance.com
Adjustable Pro Tour Style Rear Sway Bar for the 1978-1988 GM G-Body
P/N: #3044
Price: $399.99
UMI Performance, Inc. is pleased to announce the availability of our newly designed Pro Tour style rear sway bar for 1978-1988 GM G-body applications. This 1” dia hollow sway bar is axle tube mounted using our tried and true 2245 serrated tooth mounting clamps, poly bushings and heavy duty u-bolts. Three position adjustability delivers street, road race/auto-x and light drag race performance all from the same bar. Adjustable length race style rod ends allow a perfect fit as well as preload capability for drag racing use. The P/N 3044 sway bar has been designed to accommodate the factory rear housing, GN 8.5, 12-bolt, Ford 9” and Moser M9 while still offering great ground clearance and a clean look. These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA – USA.
Website Link: http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_66&products_id=722
