Ladder bars
curt461
75
Throwing out there for pros and cons thinking of putting ladder bar set up and coil overs on 87 gbody with qp 9 inch. What y'all think
Thanks
Curtis
prairiehotrodder
1,576
Melfort Saskatchewan Canada
Its allready got a 4 link. Isn't ladder bars a step backward? I would upgrade all the factory arms then install a pair of coil overs straight up and down and ditch the factory shocks and springs.
curt461
75
I do have adjustables upper and lower, what coilovers you recommend. When you say straight up and down just mean move them in some and mount straight up and down
Supe
15,116
Charlotte, NC
What type of racing do you do, and how fast is the car?
prairiehotrodder
1,576
I haven't tried it yet personally but was recomended by a much more experienced and faster racer than I. Build or buy some type of weld-in cross member to hold the upper shock mount, weld some type of lower shock mount onto the rearend tubes. Place coil overs in so they are perfectly straight up and down. This is for drag racing. Might be tough to fit it with the stock gas tank.
Brian
curt461
75
Right now messing with bracket racing, cant get a time on it spins to bad.
curt461
75
Thanks for your help Brian, any thing else you think I can try let me know
prairiehotrodder
1,576
i just got this link today
UMI could probably make you a kit as well but i think the coilovers are angle mounted to be a bolt-in.
