trz arb anit roll bar installation questions
ecc_33
289
amanda ohio
I got my new roll bar but not sure on were to weld the cross tube into the frame at? Is there a set place on the frame that this thing needs to be welded in at? Looks like behind the rear axle but didn't know how critical it is or if the bars need to be at said degrees and ride height level etc. Thanks, Eric
82wagon
98
I think the only thing needed is to have the link bars straight up and down. Hope this helps.
gman415
883
Chattanooga
I set mine as close to 90deg as possible. Straight up from the rear straight foreword* to the bar.
I was told to install in front of the rear. It works fine, just no room for exhaust and the upper control arms will hit it if the car bottoms out.
Wished i would have installed it behind the rear.
ecc_33
289
amanda ohio
Thanks, I wonder what the benefits are to installing it in front of the rearend then the rear of the axle.
gman415
883
Chattanooga
None that I know of. If I ever redo mine, it will be to the rear.
80superbu
2,253
Colorado springs, CO
Here is how mine is mounted and it was done by NRC motorsports when they built my cage
file.php
