78-83 FACTORY XMEMBER MOD FOR USE WITH 700R4
Moderator: Moderators
Post Reply
TURNA
Post by TURNA » Wed Mar 02, 2011 6:34 pm
MAKE YOUR 78-83 G-BODY XMEMBER WORK WITH A 700R4
I have used this mod with an approx 400HP small block.
I still have this Xmember in my garage after almost 10 years of use.
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
tommi3520
Re: 78-83 FACTORY XMEMBER MOD FOR USE WITH 700R4
Post by tommi3520 » Thu Nov 24, 2011 7:45 pm
I have a 79 malibu with th-200 or 250
Gonna buy a 700r4 and put in the car
Do you have more pictures like this? just to show us how the orginal looked like, because i havent begun checkin everything out, would be good to have more idea what im in for when i start.
Tommi
Preacher
Post by Preacher » Wed Jan 04, 2012 6:55 pm
I used a piece of square tubing and made a 700 crossmember for mine.
DOUG213XRJ
Post by DOUG213XRJ » Thu Jan 05, 2012 7:25 pm
Thats all I did to my stock V8 81 Malibu cross member, Was cut a few inches off the mounting pad and drill a new hole for a 700R4 install. The mounting pad need`s to clear the 700R4`s pan. V6 cross member`s may be a little different, So I would install it bolt it in and see where it hits the pan.
Doug
1978 El camino
1981 Malibu SS
Post Reply
