torque converter very thight on pump
Moderator: Moderators
Post Reply
goldie
Contact:
Post by goldie » Thu Sep 22, 2011 9:03 pm
Torque converter thight on pump hard to spin. But spins freely on old trans
SSedan64
Re: torque converter very thight on pump
Post by SSedan64 » Thu Sep 22, 2011 11:59 pm
What Trans?
Possibly a problem in the Pump, Gear clearance etc..
goldie
Contact:
Post by goldie » Fri Sep 23, 2011 5:52 am
Sorry, 350 Trans fresh rebuild. Checked jump gears spin nice and all greased up
SSedan64
Post by SSedan64 » Fri Sep 23, 2011 8:13 am
Front internal thrust clearance/end play check Ok?
There are 2 different type Pumps, 1 uses a Washer & 1 uses a Bearing behind Pump.
If they get mixed up it can cause binding.
Should probably have the Builder check it out.
goldie
Contact:
Post by goldie » Fri Sep 23, 2011 10:46 am
Nah i dont think its that a soon as I put it on its tight
SSedan64
Post by SSedan64 » Fri Sep 23, 2011 4:40 pm
Does the new Trans have an Electrical connector on the left side?
Input Shaft look like 1st or 2nd Pic?
Wondering If one's a 350C..
TH350C Input Shaft (Custom).jpg (12.55 KiB) Viewed 2621 times
goldie
Contact:
Post by goldie » Fri Sep 23, 2011 7:43 pm
Pic two. Also just took pump off and still can't get it to go on its got to be the bushing but I put it on right
SSedan64
Post by SSedan64 » Sat Sep 24, 2011 5:04 am
May have egg shape or a bad burr.
goldie
Contact:
Re: torque converter very thight on pumpgood
Post by goldie » Sat Sep 24, 2011 9:48 pm
Good To go
allisontech
Post by allisontech » Tue Apr 10, 2012 8:33 pm
If this is a Boss Hoss Alabama converter I have had 2 of them in the past that had over sized hubs, even a uninstalled new pump bushing would not fit the hub. I wont sell them anymore. You defiantly get what you pay for.
Post Reply
