TKO 600 shifting problems
Moderator: Moderators
Post Reply
kevind
Post by kevind » Sat Mar 24, 2012 9:09 pm
I've had a TKO 600 in My Malibu for a few years. It has just started to not want to go in any of the gears on the front of the shifter so no 1st,3rd or 5th. It wont go in even if the engine isn't running. Sometimes if you pat the gas and jerk the car in 2nd or 4th it will free up the shifter and it will go fine. I'll probably pull it out tommorow but I was just wandering if anyone has had a problem like this.
80 Malibu 500" BBC,TKO 600,Moser 9",Vintage Air and a few other things.
78 Malibu 25.5 car 574" All Aluminum BBC street car.
Contact:
Re: TKO 600 shifting problems
Post by t5montecarlo » Sun Mar 25, 2012 8:42 am
Please post your findings; I would like to understand why.
Post by LS6 Tommy » Sun Mar 25, 2012 11:12 am
You're not the only one. The TKO's are notorious for rail problems. Call Paul @ Liberty's Gears:
http://www.libertysgears.com/
kevind
Post by kevind » Sun Mar 25, 2012 5:07 pm
I took it out today and removed the shifter. The shifter was made in two pieces a flat base that bolts to the transmission and a round part with the actual shifter that bolts to the the flat base part with 4 bolts. 3 of the 4 bolts had feel out and wedged between the shifter rail and the trans case. I put some loctite on them and put them back in. It seems to have fixed the problem.
Contact:
Post by t5montecarlo » Sun Mar 25, 2012 5:54 pm
That was too easy. I am glad to hear the issue was minor.
kevind
Post by kevind » Sun Mar 25, 2012 6:03 pm
Thats the first minor fix in a long time it's normally a worse case scenario.
Post by LS6 Tommy » Sun Mar 25, 2012 7:29 pm
Glad it was an easy fix!
Post Reply
