transmission line problem
malibujames
41
New Carlisle Ohio
Got a powerglide in my 80 malibu it had a turbo400 in it now my problem is the fitting going into the trans and the old transmission lines dont work together. The line threads into the fitting but bottoms out before the line gets tight. the local auto parts store dont have anyone that knows anything and no help from there so does anyone have any fixes for my problem?
SSedan64
948
MACON, GA.
The Glide fittings are smaller, Case fittings are 1/8" NPT to 1/4" Inverted flare line fittings, I think the TorqueFlite also uses the 1/8" Case fittings.
Most others are 1/4" NPST to 5/16" Inverted Flare line fittings..
