Torque converter
bowtie81
5,008
sarnia, ontario canada
I'm starting to wonder if the hub on the front of my torque converter is pushing on the crank. Is it possible to put a spacer on the 3 bolts so the converter doesn't come out quite as far?
SSedan64
948
MACON, GA.
Yes you can use Spacers/Washers.
Make sure you have 1/8" to 3/16" clearance between the TC & Flexplate before sliding the TC forward to bolt it up, after adding spacers.
