WC T5 clutch/pressure plate?
Moderator: Moderators
Post Reply
Supe
Pro Moderator
Contact:
Post by Supe » Sun Jul 01, 2012 3:23 pm
Do all world class T5's share the same splines, or did it differ throughout the years and between manufacturers?
I picked up a 383sbc/T5 combo, T5 has the electronic style speedo plug and an aftermarket bellhousing (looks like a Lakewood). Slave cylinder has seen better days, and the pressure plate is binding like crazy (very heavy, very jerky clutch pedal that doesn't even come close to hitting the floor).
I was hoping to order the clutch/pressure plate ahead of time (looking for something mild/street performance oriented, as the rear end in the hill climb car will not live up behind hard shifting), but I'm not sure if I will need to yank the trans first to count splines.
Don't leave home without your Umbrella
Contact:
Re: WC T5 clutch/pressure plate?
Post by t5montecarlo » Mon Jul 02, 2012 7:36 pm
All GM V8 T5s (WC and NWC) are 26 spline. The 1993 and later V6 T5 was also 26 spline, but used a Ford-style case. It is not geared like the earlier V8 T5 and is weaker than the earlier V8 T5. The V8 T5 has a 2.95:1 first gear.
The electronic speedometer adapter is mechanically driven, so there is still a plastic drive gear on the mainshaft.
Supe
Pro Moderator
Contact:
Post by Supe » Tue Jul 03, 2012 5:15 am
Thanks! Does this mean that any of the 26 spline V8 clutches would work, regardless of what case it came in?
Contact:
Post by t5montecarlo » Tue Jul 03, 2012 8:58 am
The disc should be universal; the pressure plate may be specific to application.
Post Reply
