no overdrive no lock up /700r4
woody31
hi there, need some help, i have a 700r4 from a 92 buick roadmasterin my wagon, pproblem is no od or lock up,, took trans apart to replace tccs, od was working before this, after i swapped the tccs no 4th gear or lock up???, was working before , im thinking a stuck 3.4 shift valve or????? can somebody help me out here,,, thanks
SSedan64
948
MACON, GA.
Check the TV cable adjustment 1st.
How are you activating the TCC Lockup? Manual switch etc...
Is it 4th gear Lockup only?
