Lazy/Slow shifts
81classic
2,833
North Port, Fl
My transmission was rebuilt just before I took my car apart for the restoration about 7 years ago. Back then it had a nice firm shift, but now when under power, it has a lazy shift between all the gears. Since I've been driving the car over the last year I've put about 250 miles on it and it still has a lazy shift. I thought from sitting maybe something might have been stuck and using it would cure it. The only thing I did not hook back up was the kickdown cable. Would that have anything to do with it? I'm pretty clueless when it comes to automatic transmissions.
rob.c1989
276
Thomasville, GA
what kind of trans is it? TH350?
i would try to hook up the kickdown cable and see, i would check to make sure all the vacuum lines are connected and not leaking
SSedan64
948
MACON, GA.
Detent/Kickdown cable shouldn't cause that issue. Vacuum can.
Put a 0-300psi. Pressure gauge on it & check the pressures at Idle & 1200rpm in all gear ranges.
