200r4 and column shift
Moderator: Moderators
malibuguy
Post by malibuguy » Sun May 04, 2014 9:33 am
Im about to swap in a 200r4 and I want to retain the column shift this time.
I know ive seen late elcaminos with column shift and 200r4s...but I never took note of the linkage. Will I be able to get all gears or will I be stuck with PRND432
Im not worried about the indicator right now, just the actual gear selection
Any input would be appreciated
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
nillabu
Re: 200r4 and column shift
Post by nillabu » Sun May 04, 2014 11:25 am
I finished that same swap into my column shift car. All the original TH350 linkage was used. I also changed the indicator plate in the column. Low gear can't be selected without changing the shift detent plate "in" the column. Can't find the article that explains how to modify or change the plate. It's not a big deal unless your gonna shift it manually. The downshift cable and brackets needed to be changed out in favor of the TV cable. TV cable adjustment is critical for the 200R4 to last. I run a 4150 Holley so needed a carb. lever bracket and the proper base plate or intake cable bracket. Hope that helps.
Steve
80 Malibu/Ex-Landau/Rotisserie Resto
Mild 383 w/200R4-C/K Specs-C/K D5 Medium Stall Lockup
9" w/3.73's & 11" Disc
12" B-Body Spindle/Brake Swap & Rear Frame Notch
Jeep steering shaft up-grade-Narrowed & Rechromed Bumpers
17"x7"-8" TT2's w/BF Goodrich G Force Sports 225/50/4.75" BS-255/45/4" BS
Ya gotta be lost to find a place thats never been found
malibuguy
Post by malibuguy » Sun May 04, 2014 1:36 pm
I kinda figured I may lose 1st gear control. I vaguely remember that issue when I did the same swap in my first Malibu...but that was 10 years ago.
So really...I should keep an eye out for a OD steering column
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
melloelky
Post by melloelky » Mon May 05, 2014 9:20 pm
nillabu wrote:I finished that same swap into my column shift car. All the original TH350 linkage was used. I also changed the indicator plate in the column. Low gear can't be selected without changing the shift detent plate "in" the column. Can't find the article that explains how to modify or change the plate. It's not a big deal unless your gonna shift it manually. The downshift cable and brackets needed to be changed out in favor of the TV cable. TV cable adjustment is critical for the 200R4 to last. I run a 4150 Holley so needed a carb. lever bracket and the proper base plate or intake cable bracket. Hope that helps.
Steve
if you don't mind,which cable bracket did you use?i only ask because my new 4150 carb says to use only #### holley bracket.i didn't know if i had to use THAT bracket or another one was acceptable.
rotisserie-mod
82 el camino
406/200r4
nillabu
Post by nillabu » Mon May 05, 2014 9:46 pm
Pretty sure I used these. Both the 4150 geometry corrector lever and the TV cable bracket are here. For some reason they call it kickdown lever and bracket??? Not so...should be called TV cable lever and bracket.
http://www.holley.com/20-121.asp
Steve
malibuguy
Post by malibuguy » Mon May 05, 2014 11:26 pm
Im running a stock dualjet so im just going to modify what I have for now...I guess TIGn on the carb is frowned upon tho...lol
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
gmtofd
Post by gmtofd » Tue Jun 10, 2014 6:55 am
If you are using a Dualjet, then locate a TV cable bracket from a 307 Olds mtr. This bracket bolts to the back two carb to intake bolts/studs. Even still, the bracket may have to modified to get the correct location for the cable position.
The stock column linkage intended for a TH350 TH200 has adjustment and was able to get the detents for all 4 forward gears.
Another thing that tripped me up with the 2004R swap is the the G body frames were modified for the later years that came with the OD trans. This means on the left side an extension is needed for the Malibu frame which I think I brought from G-Force.
malibuguy
Post by malibuguy » Tue Jun 10, 2014 8:36 pm
I ended up getting a linkage kit from Lokar thats adjustable. It was a PITA to set up...partly due to how I routed my one header primary...and well just figuring it out. But after about 3~days of dicking with it, cussing and whatnot I have it sorted out!
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
malibuguy
Post by malibuguy » Fri Jun 13, 2014 7:54 pm
Got it done. All gears nice and smooth.
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
Post by t5montecarlo » Sun Jun 29, 2014 9:59 am
Does the sleeve at the column introduce slop in the linkage (is it mounted in rubber washers?)? I would expect the linkage to be curved rather than to use a sleeve.
malibuguy
Post by malibuguy » Sun Jun 29, 2014 2:23 pm
No slop at all. The bushings are Delrin actually. Very tight feeling. That spacer I had to get separately along with a longer bolt to have the linkage clear the firewall. I also had to trim a screw down as well...I think held something to do with the steering column plate. You can see it in the picture.
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
1981Regal
Post by 1981Regal » Sun Jun 29, 2014 2:59 pm
Did the brass spacer come with the kit or did you make it? The one on the colum side that attaches the rod to the transmission.
1980 Malibu coupe 468/th350
malibuguy
Post by malibuguy » Sun Jun 29, 2014 11:38 pm
I had to buy it separately along with the longer bolt in order to clear the firewall.
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
MISFITmalibu63
Post by MISFITmalibu63 » Mon Mar 23, 2015 9:38 pm
I'm currently doing this, do you happen to have the part numbers for the lokar parts you used?
1979 Chevy C30 6bt Cummins, NV4500, NP205, 25,000 mile project
1980 Malibu Classic 460 BBC, th-350 3.73 strange S60....10.91 @ 122.62
1982 Malibu Station Wagon, 355, 200-4r, 3.42 8.5, 52,000 mile daily driver
2005 Chevy Silverado 2500 HD Extended cab, short bed, 4x4, 8ft plow
BREAK S#1T RACING!
malibuguy
Post by malibuguy » Tue Mar 24, 2015 10:36 am
Ill try to dig it up later after work
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
Post Reply
