Page 1 of 1
Th350 pump thrust washer / bearing
Posted: Sun Apr 05, 2015 7:38 pm
by BillJ
Just another question with my rebuild. Used the Hughes rebuild kit and it is a good kit. My question is. When I checked end play before the rebuild their was 0 end play. Installing the pump after rebuild and replaced the torrington bearing with a new one I had 0 end play. Can you just use a new thrust washer in the place of the bearing. How do you know if the pump is machined for a bearing. There is Torrington bearings in the trans do you have to use a bearing under the pump. Please help needed to finish trans. Thanks
Re: Th350 pump thrust washer / bearing
Posted: Mon Apr 06, 2015 6:31 pm
by Pete@Hughes
Yes, you can replace the bearing with a thrust washer in order to achieve proper end-play in the TH350. You may have to shim the washer accordingly.
Posted: Tue Apr 07, 2015 1:49 pm
by BillJ
Thank you
