Cross member help
Moderator: Moderators
Post Reply
78_buwag
Cross member help
Post by 78_buwag » Fri Oct 21, 2016 9:55 pm
I bought a jegs double hump transmission crossmember for my 78 malibu wagon with a th350. My bolt holes are coming up a half inch short. Called jegs tech and we're thinking it's the same frame as an El Camino. DOES anyone know what cross member I'm supposed to run?
1978 chevy malibu wagon
383 in progress
89 s10-beat the ever livin shit out of truck
2013 crane carrier front loader
theres a reason why malibus rule the world
Re: Cross member help
Post by LS6 Tommy » Sat Oct 22, 2016 4:11 pm
The Malibu Coupe, Sedan and Wagon frames have the same suspension specs. The Elky has a longer wheelbase. Cross members should interchange for all in the same years.
malibuguy
Post by malibuguy » Sat Oct 22, 2016 5:43 pm
Jegs crossmembers have a reputation of not always fitting correctly.
All the Gbodies are the same...doesnt matter if Elco, Malibu or Cutlass in terms of crossmember requirements
The only caveat is the later ones for the 200r4, early cars require an extention. But that doesnt affect you at all with a th350
Id suggest either an Iceman tubular unit, or a Gforce (sold as a summit). Both fit excellent and work well.
The iceman is lighter then stock, the Gforce is BEEFY and is much heavier then stock but it helps reinforce the frame somewhat.
Ive run both, I got the Iceman in my turbo car(unit itself is about 7years old), and my old Gforce (10-12years old by now) is still in current use on my Dads elcamino
-Greg...the Exhaust Guy.
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
78_buwag
Post by 78_buwag » Sun Oct 23, 2016 3:25 pm
Thanks for the help for my stock on back in for now, will probably just modify this one later one
383 in progress
Post Reply
