T-56 swap info
Moderator: Moderators
Post Reply
T-56 swap info
Post by Doober » Tue Sep 25, 2007 10:01 pm
Thanks to all who have inadvertently contributed to this thread through replies to other posts on this forum
:D :nana_wrench: \:D/ bouncing.gif tongue_nah_nah.gif
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
Post by Doober » Wed Oct 10, 2007 3:32 pm
Basic T-56 info
TREMEC'S OFFICIAL PAGE FOR THE T-56
A basic rundown of what's available as far as GM T-56 transmissions (thanks Chree):
  • GM LT1 T56 ('93-'97 F-Body): Works with Gen 1 SBC, you use the LT1 bellhousing and F-Body hydraulics with John Bzdel's pedal.
  • Aftermarket T56: has an adapter plate to mount the T56 to a traditional SBC bellhousing.
  • GM LS1 T56 ('98+ F-Body, GTO, etc.): can be mated to SBC with the McLeod modular bellhousing. LINK
Linkage
There are a few ways to install a T-56 into a G-Body, depending on what transmission you use and/or what linkage you use.
Starting with the linkage:
  • First, there's the factory F-Body linkage, which utilizes hydraulic master and slave cylinders. You can most likely pick these up at a local salvage yard, or purchase them new from an auto parts store (much cheaper at a salvage yard, also more chance of premature failure). There are also two types of available slave cylinders.
    One mounts on the F-Body bellhousing:
    And the other actually slips over the input shaft, the cylinder itself pushes on the thowout bearing:
    Weir Hot Rod Products also sells a new bellhousing to use with the F-Body (OEM) T-56, it includes a self-adjusting hydraulic throwout bearing, steel block plate (clutch cover), pressure and bleeding tubes (mounted on slave/t.o. bearing), and new bellhousing and transmission bolts. They also recommend a master cylinder from either McLeod or Wilwood for proper operation. This would be a good upgrade if you came across a screamin' deal on an OEM T-56 without a bellhousing, the kit also allows you to use a standard starter, where (I believe) the starter required the factory bellhousing is F-Body-specific.
  • Next is the factory style G-Body linkage, which you can now find numerous places, including eBay and various aftermarket suppliers (Mike's Montes, El Camino Parts, Honest Charley to name a few). Also keep in mind if you are switching from an automatic to a manual that you will need to relocate/remove the vacuum/wiring that runs through the firewall for cruise control, as it uses the same hole. Here is an exploded view of the entire pedal/linkage assembly:
    EXCELLENT LINK regarding factory linkage and bellhousings, covers both 153 tooth and 168 tooth flywheels.
    If you use the factory linkage, some things also need to be considered. An aftermarket T-56 can be used with the factory bellhousing/linkage as it has a standard Muncie/Saginaw/Borg Warner bolt pattern, but if you choose to use a Camaro/Firebird-specific transmission an adapter plate is required. There are two that I've seen so far, one is from THE GEAR BOX (Garden City, MI). Their adapter plate allows the use of an LT-1 T-56 on either a standard (Muncie/Saginaw/B.W.) bolt pattern or the slightly rotated (17º to the right) T-5 pattern, which was in the 3rd generation F-Body. The other adapter plate is from FORTE'S PARTS CONNECTION (Framingham, MA) and allows the use of your factory (Muncie/Saginaw/B.W., NOT T-5) bellhousing with the T-56 from an LS-1 equipped car.
    The Gear Box's home page
    Forte's home page
    For those who already have the factory linkage, but their setup is getting slop in it, or just want an upgrade, Speed Direct has a tubular linkage setup (clutch rod, pedal to z-bar rod) with spherical ends on it that take out the slop that the original setup has.
Driveshaft
I haven't really found more than a couple sources for driveshaft length, so you might be best to measure it yourself to double check. I found a measurement for both a G-Body with 7.5" rearend, and an 8.5":
  • 7.5: 49¾" inches from the center of the rear u-joint to the tip of the output shaft - LINK to "MikeD's" page (search the page for '49 3/4')
  • 8.5: 47¼" centerline to centerline of the u-joints - LINK to John Bzdel's page (search the page for '47.25')
Crossmember
Aftermarket crossmembers are available to retrofit a T-56 into a G-Body, one of the most well known companies is Crossmembers.com. The part number for their crossmember is RCT56, and it allows you to run the exhaust on both sides of the transmission, unlike the factory crossmember which only has provision on the passenger's side. The site also states that for a '78-'83 car will need PN FE100 (driver's side extension, adds 2 mounting holes), and that '84-'88 cars don't need this extra part. I could be wrong, but I believe I've read of people just drilling through the frame where needed on the driver's side. I've also read of 'Iceman' having a T-56 crossmember (his parts can be found via the main page of this site), but from the list I've seen on the main page only showed one lightweight crossmember (he also sells the extension listed previously for the driver's side).
Post by Doober » Thu Oct 11, 2007 11:00 am
If you have any more info, feel free to post it :) Or let me know if there's something inaccurate.
79HurstOlds
Post by 79HurstOlds » Sat Jan 19, 2008 2:25 pm
I believe with the 8.5 rear the driveshaft length has to be 47.9". The stock length is 51.5 and the T56 is 3.57" longer than the 200-4R. Maybe John Bzdel's is shorter because of his LS motor??
'79 Cutlass, GMPP 350 HO, Worked Vortec Heads, Edelbrock 750, XE274 cam, T56 6 Speed, RAM Billet Flywheel, RAM Powergrip Clutch, Pro 5.0 Shifter, 4.10 GN Posi Rear, Tubular Rear Control Arms, Hotchkis Springs, Pro-Touring Rear Bar Longtubes, X-pipe, 2.5" Bullets.... Soon to be fully-built 383 LT1
Re: T-56 swap info
Post by Doober » Mon Aug 04, 2008 9:42 pm
TTT :D
388bu
Contact:
Re: T-56 swap info
Post by 388bu » Tue Aug 05, 2008 7:43 am
My swap:
http://www.shiftn6.com/6gearg.html" onclick="window.open(this.href);return false;
Not the cheapest route, but its basically bulletproof for me.
Craig
'81 'Bu - LS7/T56
'07 Sierra Denali Classic - Wester's 91/93 hot tune
www.shiftn6.com | My 6.0 swap thread | MR.com 50 fastest list
MalibuMan1979
Re: T-56 swap info
Post by MalibuMan1979 » Sat Feb 14, 2009 10:37 am
i love it. my friend is installing a t56 out of a f car in his 80 bu. he had a lot of questions about it. i told him, 'not to fear because the malibu racing people are full of info and are generous with their knowledge'. i was right. thanks all =D>
shockerman80
Re: T-56 swap info
Post by shockerman80 » Sun Mar 01, 2009 4:11 pm
Any one know what long tube headers fit with a hydraulic slave cylinder?
Re: T-56 swap info
Post by Doober » Sun Mar 01, 2009 4:19 pm
Yup. You don't need to worry about long tubes with hydraulics.
85_SS
Re:
Post by 85_SS » Sun Mar 01, 2009 5:14 pm
79HurstOlds wrote:...The stock length is 51.5 and the T56 is 3.57" longer than the 200-4R.
Stock driveshaft length with a 200-4R and 7.5/7.625" rear is 52.5" centre to centre.
EDIT: Disregard - just realized you are talking about an 8.5" rear, which is of course 1" shorter.
1985 Chevrolet Monte Carlo SS
5.7 LITRE / TES Headers / SShaker Hood / WCT5 5-Speed
1970 Pontiac GTO
Orbit Orange Judge Re-creation / YZ RAIII 400 / M20 4-Speed
Re: T-56 swap info
Post by Doober » Thu Apr 22, 2010 2:09 pm
6spdmalibu's info, mainly on pedals/hydraulics & geometry. Some info in this may be a little different/out of date now, it's been a while since I've written it #-o
http://www.maliburacing.com/forum/viewt ... =7&t=94053" onclick="window.open(this.href);return false;
SEVNT 9
Re: T-56 swap info
Post by SEVNT 9 » Fri Feb 24, 2012 12:27 am
some pics and info from my t56 swap
Its funny how replacing a rusty floor turned into a T56 swap ha ha but first things first!! out with the old!! (700-r4 boat anchor lol) and in with the new!!
1997 Firebird T56 trans, shifter, shifter ball, bell housing, clutch, pressure plate, flywheel, pedal assembly, trans mount, hydraulics, F-body T56 crossmember, inspection cover, and drive shaft fresh out of the crate from an ebay buy. 1,525.00 shipped to my place via truck freight not too bad I guess :roll:
installing the John Bzdel "bolt in" pedal:
original pedal basket
need to cut metal pedal pad down to accept smaller rubber pedal pad used for stick shift car applications, pedal bolted in, brake metal pedal pad cut, rubber pads installed on clutch and brake.
Modifying John Bzdel pedal to get exact F body geometry and pedal swing/travel:
this was something I went above and beyond to do as the John Bzdel pedal is a bolt in and works just fine!!!, I wanted the exact feel of an F body pedal.
after cleaning and painting the booster, and pedal basket assembly I bolted in the pedal with the supplied longer bolt into the brake pedal hinge point, I attached the booster to the pedal basket using washers in between to make up for the sheet metal of the body. I then connected the brake pedal to the booster push rod. This placed the brake pedal at resting pedal position/height.
I then separated the F-body clutch pedal from the F body pedal cluster (came with trans purchase from Ebay) and held it up beside John B's clutch pedal and marked where the F-body pedal pivot point sits. John B's pedal is spot on!! when compared to the F body pedal as far as front to back bends (not side to side as you can see in the pics this is because it is engineered for the A/G body cars) even the clutch master mounting point is dead on!! the pedal is a great product!!
with the John B clutch pedal bolted in and it's pedal pad lined up to the exact height of the brake pedal pad; I inspected where the new pivot point would be needed on the pedal basket, using the mark made from the previous step. At this point I could see I would have to add some metal as there was not enough metal in this location to mount a bolt, so I fabricated a plate that would then provide enough metal for a bolt to sit and still not interfere with brake pedal or other components.
the plate with hole drilled for original mounting point for brake pedal.
plate mocked up.
pedal basket grinded for good conductivity for welding
placed bolt through brake pedal pivot point to hold plate in correct spot and welded.
I then installed a new pivot point on John B's pedal using some left over round stock from a suspension kit my friend had laying around, cut it to match (width including the bronze bushing supplied with John B's pedal) then shortened the pedal to remove the original pivot point, pressed in the pivot point, and laid a few welds for extra insurance.
I also added a plate that mounts to the left upper, and lower studs for the brake booster, to aid as a support for the other side of the clutch pivot point
I placed a nylon washer on either side of the clutch pedal to keep binding down to a minimal, then double nutted the new pivot point bolt. then gave everything a fresh coat of spray paint. (the new pivot point bolt is pictured with the hex head placed against the outer support for the clutch pedal but in the car this was reversed with the nuts now sitting on that side as the two nuts interfered with the brake pedal travel.
after installing the clutch master cylinder in the car I found I Drilled/marked the holes in the firewall in the wrong location (forgot to measure twice/cut once #-o ) and once it was mounted to the pedal I found it was not aligned with the pedal travel (I removed the brake pedal, booster, gas pedal assembly, and steering column in this process to give me as much room as possible). NOTE you have to notch the left front upper column support to allow for the pivot point of the clutch pedal. (this must be done with the unmodified John B. pedal as well)
I removed the clutch master, drilled 2 more holes in the correct location and "clocked" the clutch master cylinder into the proper location at which everything was now aligned.
then checked for clutch master travel and found I could bottom out the master with no problems and pedal did not interfere (had more than plenty of room!!) I had sooo much room because pedal height was WAY off!! (not quite sure where I went wrong but I did fail geometry :-k )
I attempted to make the master adjustable using a heim joint a co-worker gave me, then using a grade 8 bolt (with the head cut off) and a sleeve I used a die to put threads onto the clutch master pushrod.
The heim joint head was too thick and caused the push rod to no longer be aligned with the angle of the pedal travel, and was also rubbing in some areas...I reused the sleeve, and took the original eyelid from the clutch master, shortened it by about an inch, and also used a die to put threads on it, I then welded the sleeve to the master side of the pushrod, then placed a jam nut on the eyelid side of the pushrod to make it easy to adjust. Adjusted the pushrod to set pedal height.
after setting pedal height I measured and installed a pedal stop so that I wasn't overdriving the clutch master set it to 15/16" travel, marked its location and welded it to the clutch pedal. the adjustable "homemade" clutch master allows me to set pedal height/clutch master pushrod stroke. (sorry not the best pic)
I removed the bell housing from the T56 and mounted it the engine and then mounted the clutch slave to the bell housing, at this point I realized two things: first The factory hydraulic line was not long enough to reach between the clutch master and slave cylinder comfortably so I needed to go longer/aftermarket. and second I found that where the line exited the slave was just too close to the header on the drivers side bank for my liking.
Purchased a 90 degree AN fitting, AN adapters for the slave and clutch master, and an aftermarket line. I used the hydraulics (master/line/slave) that came with the trans from ebay just for mock up but ended up purchasing a new master, and slave cylinder (with bleeder screw built in it). Bleeding the clutch system was the biggest Pain in the you know what, but with a vacuum pump, and plenty of fluid I finally got it bled....I never want to do that again lol Did I mention I am glad I was also replacing my floor too :mrgreen:
old slave with fitting/new line used for mock up
I resurfaced the flywheel that came with the transmission purchase, and replaced the clutch, pressure plate, throw out bearing, and pilot bearing with a kit from SPEC, a stage II LT1 T56 clutch kit.
Cant find any pics of the clutch and pressure plate bummer I know I took some not sure if I saved them or not #-o .
I found I was unable to fit the originally equipped single diaphragm "pancake" brake booster against the firewall with out pinching the clutch fluid feed line right at the clutch master coming from the clutch master reservoir as the diameter of the single diaphragm was too large. So I purchased a monte SS dual diaphragm booster, and brake master cylinder. I then fabbed up some brackets one to hold my fuel isolater for interior fuel psi gauge, and the other to hold the clutch fluid reservoir.
after getting everything in and tight, welding in the new floor you can see pedal height is perfect!!
I used the Iceman T56 cross member, and frame extension, I was able to re-use my drive shaft (as I had already done a 700-r4 swap prior). sorry no pics of this.
I cut the hole in the floor for the shifter too large so I made a small patch panel, and installed a lower shift boot from a 95 camaro I got off of ebay for 20.00 bucks with small self tapping sheet metal screws. The original shifter came with the trans but had an aftermarket shift knob on it that was hot glued to it because the threads were not right, the previous owner of the transmission cut the shifter down to make a shorter handled shifter (I am assuming) and then attempted to re-tap it....I cut off his mess found a bolt (VW passat axle bolt ha ha) that has the same threads as the shift ball, cut the head off and welded it to the factory shifter.
after replacing portions of the floor with 3 patch panels, and re-welding/fixing a botched 4th I seem sealed and painted the floor with herculiner pick up truck bedliner ha ha "cheap mans carpet" lol
I had to replace my Mechanical speedometer with a digital speedometer as this T56 trans has no speedometer cable connection just electrical. Autometer was very cool about this!! I spoke with a woman over the phone and she agreed to allowing me to trade them my mechanical speedometer for the electrical and only had to pay some silly re-stocking fee of $15.00 (that versus the 200.00 price tag is ok with me ha ha they didn't even charge me the difference between the two!! either its a super awesome company!! or some one got fired! lol but either way the speedometer is forever programmable, so there would be no issues if I were to ever change tire size or rear end gear ratio pretty neat!!!
wired in the reverse lock out to my brake light switch so when shifting to reverse I must step on the brake first, wired in the speedometer, and wired in the reverse lights using a pigtail set I purchased off of ebay. sorry no pics of this.
first start up with trans installed, no brakes yet. "click on it to play"
http://youtu.be/uyjsqPRVkTY" onclick="window.open(this.href);return false;
http://youtu.be/YJBMzISDq6Q" onclick="window.open(this.href);return false;
I then cut off the hanging exhaust (the cross pipe in the "H" was now hitting the T56 crossmember)
got it off the jack stands, made sure everything was nice and tight, brakes connected, all electrical stuff was plugged in and taken care of I went straight to the exhaust shop, had the manual cut outs re-installed and exhaust connected with another "H" pipe and then went for a ride. cruising around the streets was fun and the transmission shifted nice but seemed some what sloppy I'm sure it has had it's share of abuse and miles on it....On the highway it seemed to lurch up and down in gear, I literally got to drive it about a week before insurance ended and snow began to fall :cry: that following spring I re-insured it and back out on the streets!! I got to drive it another week.....even before the clutch "break in" period I got on it a couple of times (who could resist lol) one night I took this chick for a ride!! being the most awesome person and intelligent person on the planet :^o I decided to try to impress her 8) in the process of a quick 1-2 shift after laying some rubber in my alley all I heard was grinding :-s and never made it into 2nd.... had enough momentum to roll right in front of my garage and reversed into it. I looked over and she had this smile from ear to ear, she had no clue what had just happened so I played it off as Joe cool 8) but on the inside I was ](*,) lol I had just turned 2nd gear into dust!! but never said anything to her ha ha and she was impressed but I can't go into details ha ha :-# .... I soon had it back up on jack stands and the trans out of it in less than 1.5 hours!! something the automatic would of at least taken 4 hours to do!!
out in 1.5 hours and before noon ha ha!!
took this shortly after the trans was out and I finished wiring some new toys in!! :twisted:
http://youtu.be/qAyIB973iA4" onclick="window.open(this.href);return false;
had the T56 completely rebuilt and 2nd gear replaced by a company because I didn't want to deal with the head ache. After having it rebuilt I enjoyed it all summer long!!! no more lurching on the highway, nice and solid shifts, no play in the shifter, I turn about 1700 rpms with a 235/70/15 tire with 4.10's in 6th on the highway at 70 mph!! and the car is sooooo much fun to drive now!! I wish I would of done this swap a long time ago!! I have put on at least 1000 miles since the rebuild with no issues (other than a tail shaft leak which I think is being caused by my worn rear suspension, it's on the "to do list"). But I really just wanna say a big thanks to this board for all the advice and help, tips, tricks, words of wisdom, and everything else I left out that you have done to help me make this swap happen!!! I couldn't of done it with out this wonderful gearhead family =D> and a big thanks to my friends Eric Waldier and Gerard. I put this post up in hopes that it may just help some one else down the line. If I left anything out let me know and I will revise this thanks for reading and again for all the help.- Shawn
I use to be "bu min v8"
'79 malibu classic, factory bucket/floorshift car: 355, vortec heads, Holley 670, Edelbrock RPM airgap, Comp extreme energy 268, Dynomax ceramic coated headers, 2.5" mandrel bent exhaust from Jegs, T56, 8.5 GN rear, 4.10 richmond gear, moser axles Monte ss booster & master.
fastest 1/4 mi = 13.211 @ 100.78, 1.761 60 Ft on street tires! (700-r4) 12'S OR BUST!
Post Reply
