Could somebody give me a straight answer please
Moderator: Moderators
Post Reply
FLAV-A
Post by FLAV-A » Thu Feb 02, 2012 12:22 pm
Hey guys,
i am swapping a 700r4 into an 84 monte carlo ss that originally had a 350th. 700r4 Transmission is installed, drive shaft is in. I want to retain the factory style console shifter. Will a 2004r overdrive factory shifter, cable, trans bracket, and shift lever work with my 700r4? I haven't gotten a straight answer from anyone. Can someone answer that has done the swap? Thanks
Randy W
Re: Could somebody give me a straight answer please
Post by Randy W » Thu Feb 02, 2012 12:28 pm
I can't say, but I can tell you that with a very minor mod to the shift lever on the side of the tranny your current shifter setup will shift all the gears and give near perfect alignment with any factor 4 speed indicator.
Randy W
Barrell rolling into the sun.....
axisg
Post by axisg » Thu Feb 02, 2012 12:35 pm
Randy W wrote:I can't say, but I can tell you that with a very minor mod to the shift lever on the side of the tranny your current shifter setup will shift all the gears and give near perfect alignment with any factor 4 speed indicator.
** Bingo, when I swapped the 350c to 200r4 into my 84 I had to tweak the bracket in able to shift all the way thru from park to low gear. There was a cut and weld involved to get the bracke to line up with the holes in the trans pan. Although in my instance I used the trans bracket from my 350c on the 200r4. Once the bracket was bolted in I found that setting the shifter and trans in low gear first went a long way to aligning everything else ( catching Neutral and reverse in their proper detent on the shifter relating to the transmission ). We had to do the same in a friends car when swapping from 200r4 to 700r4 as the bolts did not line up on his trans pan either. Once you have it close there is a jam-nut on the bracket attaching to side of the trans allowing appx 1" of travel and adjsutment.
FLAV-A
Post by FLAV-A » Thu Feb 02, 2012 2:52 pm
so i guess thats a "no"? Does anyone of u guys have any pics?
Anyone else swapped from a 350 to a 700r4?
axisg
Post by axisg » Thu Feb 02, 2012 7:33 pm
FLAV-A wrote:so i guess thats a "no"? Does anyone of u guys have any pics?
After all I wrote why would you think it won't work? I just explained that it will work, you just need to do a little cut and paste to make it work. Due to the face the Gbody was never equipped with a 700r you have to make it work.
I will look thru my older pics and see if I have any for you.
SSedan64
Post by SSedan64 » Fri Feb 03, 2012 3:08 am
You may need to slot one or both of the mounting Bolt holes on the 2004R Bracket but, it will work with the 700R4 Trans.
2004R Bracket > http://www.montecarloss.com/TCC_3.jpg" onclick="window.open(this.href);return false;
B&M Bracket > http://www.summitracing.com/parts/BMM-30498/" onclick="window.open(this.href);return false; it fits most GM Trans TH250/TH350/TH375/TH400/2004R/700R4.
FLAV-A
Post by FLAV-A » Fri Feb 03, 2012 1:25 pm
thanks guys,
well i'm gonna to buy this 2004r shiter setup.
any pics will be appreciated
Post Reply
