G-Body suspension torque specs
Discuss how to make your car hook, bounce or hug corners.
Moderator: Moderators
Post Reply
Post by Doober » Thu Apr 23, 2009 4:11 pm
Putting this up to help anyone looking for 'em :) It's out of my '78 Chevrolet passenger car repair manual, but the specs probably apply for most G-Bodies.
Disclaimer: If you break your bolts it's not my fault :P :lol:
Front Suspension
  • Ball joint stud nuts
  • Upper stud - 60 lb. ft.
  • Lower stud - 83 lb. ft.
  • Joint to upper arm (bolt-in service replacement)
  • 10 lb. ft.
  • Control arm pivot to frame
  • Upper - 46 lb. ft.
  • Lower (nut only) - 62 lb. ft.
  • Shock absorber
  • Upper end - 90 lb. in.
  • Lower end - 20 lb. ft.
  • Stabilizer bar
  • Link nuts - 150 lb. in.
  • Bracket bolts - 24 lb. ft.
  • Caliper bolts
  • 35 lb. ft.
Rear Suspension
  • Upper control arm
  • Front bushing nut - 70 lb. ft.
  • Rear bushing nut - 73 lb. ft.
  • Front bushing bolt - 70 lb. ft.
  • Rear bushing bolt - 80 lb. ft.
  • Lower control arm
  • Rear bushing nut - blank (70-73 lb. ft.???)
  • Rear bushing bolt - 73 lb. ft.
  • Shock absorber
  • Lower nut - 62 lb. ft.
  • Upper nut - 12 lb. ft.
  • Upper bolt - 20 lb. ft.
  • Pinion nose bumper
  • 8 lb. ft.
  • Stabilizer mounting bracket to control arm
  • 35 lb. ft.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
Canadian-T-Bone
Re: G-Body suspension torque specs
Post by Canadian-T-Bone » Sat Jun 13, 2009 8:31 pm
could we put this into the tech section ?????? Mods ???
82 Cutlass 350/th350/7.5 with posi & 3.42 oohhh wait till you see what I'm going to do to this car ! Start shaking your head ........
Daring to be different @ any cost !!!!
80ECLT
V6 Guru
Post by 80ECLT » Fri Oct 16, 2009 10:37 am
Good job doob! Those pretty much match what I have in my books dead nuts.
Note: Those specs are for factory components. Some aftermarket parts will require different torque specs.
"El Camino's Unlimited" Sheboygan Falls, WI 53085
1980 El Camino "LT" 4.3 Liter Vortec, Saginaw 4-Speed
The worlds first and only, therefore fastest L35 G-Body!!
"He drives an El Freakin' Camino! That's like the Cadillac of cars!"
Post by Doober » Fri Oct 16, 2009 11:19 am
Hopefully it should match, it's from a Chevrolet factory manual! :mrgreen:
80ECLT
V6 Guru
Post by 80ECLT » Fri Oct 16, 2009 11:41 am
HAHA! True!
Post by LS6 Tommy » Sat Jul 10, 2010 10:42 am
I would add that all the A-arm & rear suspension hardware should be torqued with the car on the ground, or at least with the tires at ride height, unless you have Delalum bushings or spherical bearings.
monte ss496
Post by monte ss496 » Mon Dec 13, 2010 10:55 pm
should this be a sticky?
"hands cant hit what the eyes cant see, float like a butterfly sting like a bee , rumble young man rumble"
85 monte carlo ss 496 bbc th400 strange dana 60 !!!!!
79 malibu same drivetrain best pass 10.60 at 129 SOLD!
V8 Rumble
Post by V8 Rumble » Tue Apr 26, 2011 8:39 am
Nice! This is great!
Do you happen to have the specs for the outside uca shafts torque specs?
Post by Doober » Tue Apr 26, 2011 11:17 am
It's likely if they're included in the manual, but those are up in Michigan :?
Post by LS6 Tommy » Sun Sep 18, 2011 10:56 am
V8 Rumble wrote:Nice! This is great!
85 lbs/ft.
Post Reply
