Lost drivehsaft at speed, damage ensued.............
383S10
581
Huntsville, AL
lilbowtie said:
It kinda looks you might have had a cracked tail shaft earlier with the sealent you used. Anyway check your bellhousing area for cracks, I've broke 2. I would also do some reading on driveshaft critical RPM, Precision Shaft Tech has a nice reference chart. This bit me once also. Hope all you need is a new tailshaft housing. Nice car - would like to know how that interior goes.
That sealent is where tailhousing and trans case comes together.....I had a drip there after replacing the rubber seal......just a drip at the bottom the sealent was spread on the outside not in joint...........
LOL I need to update that signature.....the interior was completed back in May 2011 before I went on the Hot Rod Power Tour........
gman415
883
Chattanooga
Mariah Carey......Really?
Sorry for the mishap, interior looks good.
383S10
581
Huntsville, AL
Lol............I had just got it and was loading up the channels........everytime I post that photo I catch heck for it......it funny to me.......
383S10
581
Huntsville, AL
I scored these seats from a Pull-a-Part for $50 for the front and rears...I bought a grey set and a black set to install. I used SEM paint to dye paint the seats. If you use them out of a 91-93 LeSabre the front holes line up perfectly the back only one will line up and the other you will have to enlarge the hole some to get it to set flush. You can experiment with your present seat brackets to see if the will swap over to the new seats and bolt in......I ve seen that happen with other g-body seat swaps. If you want a bucket seat style seat up you have to use two passenger seats with a console or you can just use it as a bench seat. Here is some pics of the painting, console build, and the install of the seats....I added a new headliner and carpet also......
Check out these links to see the guy who inspired me to do this........
http://rides.webshots.com/album/155414205PmrdRn
http://good-times.webshots.com/album/55 ... R?start=48
http://rides.webshots.com/album/2167471 ... X?start=12
