6.0 motor and transmission are in!!! - NOW A STICKY
MetricBoo
19
What exactly did you change (changed heads, intake, carb, and transmission (went with a transbrake) to try and run a 9?
How much of a shot were you using?
Thnx.
Roller406Bu
396
Elizabethtown Ky
Thnx.
Yes I changed all that you mentioned and a new yank 3600 nitrous convertor.. 150 edelbrock plate
MetricBoo
19
Sorry I should have been more specific.
-What carb did you have and what do have now (cfm/model)
-What model trans are you running ( PG, th-350, 4L80E)
-What intake? I see your using TFS 220's which are cathedral port I thnk?
I'm just curious as this is simliar to my combo.
Thanks,
Roller406Bu
396
Elizabethtown Ky
Thanks,
317 heads to as cast 220's TF
750 dp holley to a 950 quickfuel
350 turbo to a 400 turbo
victor jr to a super victor and yes cathedral...
1 3/4 headers 3inch collector to 1 7/8 with 3.5 collector as well
MetricBoo
19
Did you make any motor passes with the new parts before the diff let go?
What diff did you have?
Bad *ss Car, very very clean!
Roller406Bu
396
Elizabethtown Ky
Bad ### Car, very very clean!
yes picked up 3mph 1/8 mile track from 95 to 98.6 right off the trailor track is far away....convertor is very tight....hears the vid u can tell how it lugs it down....I'm embarrased to post a et...lol
car is full weight 3480 before the cage don't know what it weighs now...it wasnt a nodular center...i have a new moser nodular center in it now should be okay...thanks..
Hy82e
New Member
Dec 6, 2012
Fort Worth, TX
What are you using for the front suspension? Do you have it set up as a drag car?
I'm building a street/daily car. Full suspension, sway, bracing, AC. I'm trying to get an idea of spring rate for the car since I will not know the front end weight of the car until its all put back together, and I hate the idea of doing front springs more than once.
Roller406Bu
396
Elizabethtown Ky
qa1 coilovers with a 350 pound spring...its a street car 80% of the time but is set up for drag....no sway bars....full weight car 400 wouldn't be out of the question i had to crank and crank on the spring perch to get the front end up on mine with the 350...
82dragonwagon
35
what headers are you using with this swap? I think I'm going to nix the turbo and pull out the 4.8 and do a 6.0 w/l92 heads and holley highram intake and comp cams.
