i've picked up a few parts recently. grabbed a manual pedal setup, and swapped my john bzdel clutch pedal in. all is good except the bushings on the brake pedal need to be replaced, a little too worn for my liking. anyone know where i can pick these up?
i looked into a shifter relocation kit, and its $400!!! might just see how far back the stock location will be before i commit to it.
also found a way to "override" the electric solenoid for the reverse lockout.
I received the flywheel, 22 lbs of steel. it has weight bolted to the back, so im going to have to call spec and figure out if it should stay or go for my setup :roll:
i've been looking online, and i think i'll go with an upgraded "stock" clutch, seeing as how i don't plan to race this, and my engine doesn't make much more than the stock camaro setup.
