Converting the Slow-wagon to t-56
Moderator: Moderators
Re: Converting the Slow-wagon to t-56
Post by Doober » Wed Jun 10, 2015 2:03 pm
I drove the Malibu pretty hard on the factory clutch setup, and the only time it didn't grab hold was when I was shifting fast as I could, even then it was just a very short slip, you should have nothing to worry about.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
Post by t5montecarlo » Wed Jun 10, 2015 8:29 pm
Doober wrote:the only time it didn't grab hold was when I was shifting fast as I could, even then it was just a very short slip
That doesn't happen with the Hays disc that I have. At the track, I chirped 4th gear (the T5 will allow you to shift without lifting the gas pedal). the disc looks like it has wires in it, yet it still engages smoothly.
Mike, the pedal bushings are common for almost all GM applications for many years. Dorman/HELP has them.
RatMalibu
Post by RatMalibu » Wed Jun 10, 2015 9:43 pm
as far as the reverse lock out, I just hooked mine up to the brake light switch...it disengages when I hit the brake
Matt
Post by t5montecarlo » Wed Jun 10, 2015 9:56 pm
That is an interesting idea. Did you splice into the brake light harness? or use the other socket (for cruise control release) and install a separate brake lamp switch?
RatMalibu
Post by RatMalibu » Thu Jun 11, 2015 10:27 pm
I just spliced into the brake light harness, but I suppose that using the other socket would be better
Matt
Post by Doober » Fri Jun 12, 2015 8:36 pm
I was considering that or a button on the shifter ball if I went with a T56.
Post by t5montecarlo » Sun Jun 14, 2015 7:30 pm
Can the solenoid be removed altogether? Is it common to miss the 6th gear gate and engage reverse by mistake? Or can something else be put in its place with a spring that is stiffer than the 5-6 gate, but not overwhelming?
MISFITmalibu63
Post by MISFITmalibu63 » Mon Jun 15, 2015 7:35 am
ordered the clutch kit and new hydraulics, just have to convert to manual speedo setup and decide if i am going to relocate the shifter or notch my bench
1979 Chevy C30 6bt Cummins, NV4500, NP205, 25,000 mile project
1980 Malibu Classic 460 BBC, th-350 3.73 strange S60....10.91 @ 122.62
1982 Malibu Station Wagon, 355, 200-4r, 3.42 8.5, 52,000 mile daily driver
2005 Chevy Silverado 2500 HD Extended cab, short bed, 4x4, 8ft plow
BREAK S#1T RACING!
Post by t5montecarlo » Sat Jul 04, 2015 7:36 am
Have you decided whether to replace the tailshaft housing with a modified one? or to use the device that converts VSS pulses to a motor that spins the speedo cable?
Killerdave8813 uses the converter in his car.
MISFITmalibu63
Post by MISFITmalibu63 » Sun Jul 05, 2015 8:01 am
I'm going to convert the trans to a mechanical speedo, don't want to run extra wires, and converting isn't much more than the cost of the box.
Anyone relocate the shifter on a stock t-56?
This has taken a back seat until I finish putting the 2 door back together
BREAK S#1T RACING!
Post Reply
