TH-400 case
Moderator: Moderators
Post Reply
pldmalibumalibu
TH-400 case
Post by pldmalibumalibu » Sun Apr 05, 2015 7:06 am
I was told that the 6 bolt case I have will not be good for a perfomance rebuild . Do I need to go find a 8 bolt case now ? The trans I have now has HD 46 cast into the bellhousing and the front pump has the 895 on it.
1981Regal
Re: TH-400 case
Post by 1981Regal » Sun Apr 05, 2015 11:39 am
I have never heard anything like that?
1980 Malibu coupe 468/th350
pldmalibumalibu
Re: TH-400 case
Post by pldmalibumalibu » Mon Apr 06, 2015 11:16 am
Im hoping the moderator Peter Hughes will give me some insight.
1981Regal
Re: TH-400 case
Post by 1981Regal » Mon Apr 06, 2015 11:48 am
They might be referring to the 4L80E but the th400 should be fine. Far as I recall all the th400s have a 6 bolt tailshaft housing.
Pete@Hughes
Re: TH-400 case
Post by Pete@Hughes » Mon Apr 06, 2015 6:24 pm
We have not found any significant power limitations (within reason) to the 6-bolt TH400 transmission case. We have a customer with a 3,000 pound drag radial car equipped with an alcohol EFI 632 and an F-3R 136 ProCharger utilizing a 6-bolt TH400 case without any issues. Another customer of ours runs a 6-bolt case behind his 498 DRCE II combination that turns upwards of 10,200 RPM, and, again, has had no issues.
We do prefer to use an 8-bolt case when we're building a unit for use with a JW Ultrabell simply because having the extra two bolts in there provides an even stronger joint between the bellhousing and case, but we've used JW bellhousings on 6-bolt cases without any problems as well.
Pete Nichols
Sales Manager / Tech Support
800-274-7223, ext. 209
602-889-3621
pete_n@hughesperformance.com
http://www.hughesperformance.com" onclick="window.open(this.href);return false;
pldmalibumalibu
Re: TH-400 case
Post by pldmalibumalibu » Tue Apr 07, 2015 12:32 pm
Pete@Hughes wrote:We have not found any significant power limitations (within reason) to the 6-bolt TH400 transmission case. We have a customer with a 3,000 pound drag radial car equipped with an alcohol EFI 632 and an F-3R 136 ProCharger utilizing a 6-bolt TH400 case without any issues. Another customer of ours runs a 6-bolt case behind his 498 DRCE II combination that turns upwards of 10,200 RPM, and, again, has had no issues.
Thanks for the info. I have a 78 Malibu that weighs 3600 lbs with the driver .Its got a F1a ProCharged 468 Big-Block . Stepping up to a TH-400 & a 9''rearend so I can turn up the boost. I was curious about the case because I had never heard of people shying away from the 6 bolt cases. The car goes 10.02 now with a TH350 & a 8.5 GN rearend but the trans let go at the end of the season so Im doing it all at once so im not cutting the driveshaft more than once. I run Radial -Pros & will be using a trans-brake.
Pete@Hughes
Re: TH-400 case
Post by Pete@Hughes » Tue Apr 07, 2015 1:42 pm
pldmalibumalibu wrote:Thanks for the info. I have a 78 Malibu that weighs 3600 lbs with the driver .Its got a F1a ProCharged 468 Big-Block . Stepping up to a TH-400 & a 9''rearend so I can turn up the boost. I was curious about the case because I had never heard of people shying away from the 6 bolt cases. The car goes 10.02 now with a TH350 & a 8.5 GN rearend but the trans let go at the end of the season so Im doing it all at once so im not cutting the driveshaft more than once. I run Radial -Pros & will be using a trans-brake.
No issues at all with a 6-bolt case in that combination. You have nothing to fear. Whoever is telling you to avoid that case is providing incorrect information.
Pete Nichols
602-889-3621
pldmalibumalibu
Re: TH-400 case
Post by pldmalibumalibu » Tue Apr 07, 2015 2:45 pm
Thanks again.
lilbowtie
Re: TH-400 case
Post by lilbowtie » Tue May 12, 2015 6:40 pm
Every T-400 I have taken apart w/ a 6 bolt pump has had a case that would accept an 8 bolt.
Post Reply
