Transmission Swap Tech
Practically any transmission GM produced will fit in your Malibu. I will cover the more popular automatic transmission swaps (manual is covered in another tech topic). First, let's start with a table showing the dimensions of the most common automatic transmissions. |
Transmission | Width at Bellhousing | Overall Length | Front Edge to Mount Pad |
Powerglide | 19" 19" |
25 23/64" 27 9/16" |
20 9/16" 20 9/16" |
Turbo 350 | 19 1/8" 19 1/8" |
27 11/16" 30 11/16" |
20 3/8" 20 3/8" |
Turbo 400 | 20" 20" 20" |
28 3/8" 33 27/32" 38 1/8" |
26 15/16" 26 15/16" 26 15/16" |
2004R | 19 1/8" | 27 11/16" | 27" |
700R4 | 20" | 30 3/4" | 22 1/2" |
Vette 700R4 | 20" | 29 7/8" | 22 1/2" |
TH350, Powerglide,
Saginaw
and Muncie
All of these use the stock TH350 crossmember and the stock length driveshaft.
TH400 or 2004R
700R4 Go to this site for all the details: http://www.angelfire.com/80s/monte/transmis.htm
T5 - 5 speed swap Check out these links for information on swapping a T5 into your
Malibu/A-Gbody:
T56 - 6 speed swap Check out John's excellent site where he swapped a LS1 and T56 into his
Monte SS:
DriveShaft Issues |
If you see any info that is incomplete or incorrect please contact me!
Copyright 2001 MalibuRacing.com. All rights reserved
