i just got a set of spindles/ brakes off of a 1994 caprice classic. from what i understand, i can use the spindles and calipers, just not the rotors because they are 5 by 5 bolt pattern. so i use the camaro iroc rotors and everything will work?
Gaslight said:The 1LE was an upgrade option over the IROC. Most came radio delete, no rear window defroster, heater only. But they also came with larger brakes, stiffer suspension and so on.
Jake
